Hello,
I was hoping I could get some help with repairing my Marantz. A few weeks ago I decided to "tweak" the bias current on this amp (Why didn't I leave it alone?) and in the process blew the two power transistors on the left channel. I have replaced all transistors on the left channel (I am waiting for the 2SC3419 to turn up). I also replaced three low-value resistors that had blown. I got a copy of the service manual and checked all resistors as well. BUT I came to check the B-E resistance on the transistors to compare them with the good channel and some are way off (The A1303's are nearest the HDAMs): Tran. L R (kOhms) 1303 3.14 3.53 1837 3.77 3.74 3419 2.01 2.01 4793 5.24 5.26 3284 3.03 3.73 I set the left trimmer to the same value as the right channel (about 1.3k) Here is a picture of the boards: http://img137.imageshack.us/img137/645/dsc037438hj.jpg Any ideas what I need to do to get the resistances for the two main power trannies correct? Any other advice about my problem? If I have changed the transistors on one side only will it affect the sound of the amp? Or is it best to just get another board altogether? Marantz quoted £240 to replace the board but apparently its £90 just for the part. |
#2 |
Can someone kindly give me some advice?
Until I can get this sorted I am without my amp
#3 |
Hello, if you change the output transistors with a good type (sanken!) I think will be the right way (pay attenction to the counterfeits transistors labelled like originals...). You have to make a bias correction, so I think that maybe dangerous.
Often when you turn the bias trimmer a little, the bias current increase much much more, you must pay attenction, you must have a digital multimeter (two are better) for checking the incoming currents. I don't know if Marantz on pm 17 kis select output devices strongly. You can try to change the defective couple only and (after the regulations and few hours of works) make a listening check. Can you send me a copy of service manual at my e-mail address (I'm waiting for a defective pm 17) ? Thanks walter |
| Marantz 250M Repair | PB2 | Solid State | 49 | 11th January 2012 05:09 AM |
| Help Need To Repair Marantz Pm 94 Class A Amp | seafire | Solid State | 18 | 23rd November 2009 08:47 AM |
| Marantz CD63 Repair | big jim | Digital Source | 0 | 24th September 2007 05:45 PM |
| Marantz PM-17 repair | hirafu_boarder | Solid State | 0 | 20th July 2007 01:25 PM |
| Peculiarity in Marantz PM17 schematics | ergo | Solid State | 4 | 10th January 2002 11:32 PM |
| Page generated in 0.06747 seconds (74.71% PHP - 25.29% MySQL) with 10 queries |
