I have motorola transistor :
- SJ2394, SJ2395, SJ1671, SJ437 I don't have a transistor data, someone help me for data ! Thank's |
#2 |
None of these numbers ring a bell. Except perhaps SJ437 which could be 2SJ437 but is a Sanyo mosfet.
2SJ437: V-MOS, 30V, 35A, 50W, <30mohm (15A) Could you provide a picture? /Hugo |
#3 |
Motorola SJ numbers are house numbers for some OEM. They are not industry numbers. For example SJ6357 is the number they put on an MJ15003 for Peavey. Those numbers are considered proprietary, so Moto won't tell you. If you can find the SJ number in an NTE book or similar, you can get a rough idea of the likely specs.
Do you know what equipment they came out of? |
#4 |
Hi Enzo,
I wouldn't trust the ECG or NTE books on those either. As far as Motorola is concerned, those parts do not exist.. Bem-bem, Do you know the make and model of the unit they came out of? I'd be looking at the supply voltages and expected power output to make a replacement if I were you. If they came out of an old power supply or servo, pitch them, or use them in an undemanding application. -Chris |
#5 |
Chris,
Are those Marantz part numbers? |
#6 |
Hi Joe,
So hard to tell. I've seen other equipment with SJ series numbers. Power supplies and other things as well. A pox on those who like to keep secrets. Carver used "Cxxxx" numbers. A dark time. -Chris |
| Motorola transistor for Marantz 1200B | alex1059 | Parts | 3 | 8th February 2008 09:41 PM |
| Best driver for MJ15024/25 motorola transistor | aht | Solid State | 109 | 10th January 2007 07:54 PM |
| motorola transistor part number | contaxchen | Solid State | 6 | 25th February 2005 02:46 AM |
| Motorola transistor...69-206? | Stuart Easson | Parts | 4 | 7th November 2004 07:45 PM |
| Page generated in 0.08402 seconds (72.53% PHP - 27.47% MySQL) with 10 queries |
