Old 29th November 2002, 06:13 AM   #11
yeti is offline yeti  Germany
Default Resistor
You can try to separate the shield in the RCA jack, then connect the resistor to the ground of the jack and the shield on the other side of the resistor.
This should give you a sufficient impedance in the ground loop.
You may try different values of the resistor if the distortion isn't sufficiently cancelled, but don't take values that are too high, because this will cancel the effect of the shield.
Old 2nd December 2002, 06:22 AM   #12
hacknet is offline hacknet  Singapore
Default Re: Resistor
therefore i connect the ground of the output cable to the ground of the output socket?
Old 2nd December 2002, 11:55 AM   #13
Default resistor
yes, via the resistor.
Old 2nd December 2002, 12:02 PM   #14
Originally posted by Nelson Pass
Otherwise, I would say forget it. Burn the music to CD's
and play it on a portable player.
Don't forget to invest in good headphones.
Old 2nd December 2002, 03:43 PM   #15
what brand of headphones are good?
LM1875 bridge config Tincho Chip Amps 16 11th March 2012 06:44 AM
D'Apolito config. in Bassbox pro... turboyam Multi-Way 3 16th June 2008 09:37 PM
Need some help on speaker config pityocamptes Car Audio 11 4th October 2007 12:59 AM
831882 in an MTM config? weinstro Multi-Way 2 24th September 2007 04:02 PM
EL 84 Pentode Config. SINGLEENDED Tubes / Valves 26 5th April 2007 01:27 PM
Page generated in 0.09553 seconds (68.49% PHP - 31.51% MySQL) with 10 queries
