diyAudio (
-   Solid State (
-   -   2SJ104 Spice model (
cs 25th May 2006 01:29 PM
2SJ104 Spice model
Does anyone have a Spice model for the Toshiba 2SJ104 p-channel jfet ?
rtirion 25th May 2006 01:50 PM
2sj104 model
.model 2sj104 PJF(Beta=.108 Rs=9.661 Rd=9.661 Betatce=-.5 Lambda=3.626m
+ Vto=-.5426 Vtotc=-2.5m Cgd=88.37p M=.326 Pb=.3905 Fc=.5
+ Cgs=76.59p Isr=874.9f Nr=2 Is=87.49f N=1 Xti=3 Alpha=10u Vk=100
+ Kf=1E-18 Af=1)
cs 25th May 2006 02:04 PM
Many thanks !
jlithen 8th April 2017 06:26 AM
4 Attachment(s)
Where did anyone find 2SJ104 ? :)
I just ordered 60pcs from HKutsource and all fakes!
I am looking for a source for 2SJ74, 2SJ104, 2SJ108, but I only find a few seller having them for like 11/pc. The cheap ones are always fake!
I measured thickness, they are 3.5mm, much thinner than Toshiba. Should be about 4.0-4.1mm. They have been sanded down and remarked.
I measured RDS, it is around 95 to 115ohms in the 6 I measured, should be 40ohm.
I also measured IDSS and it was around 17mA for the 4 I checked, should be 6-12mA
Also I measured Yfs to be 8-9ms in the same 4, should be 30ms typical.
We should start a thread listing sources with fake and genuine parts. :mad:
Resources saved on this page: MySQL 18.75%
