DuPont Kapton MT as IC/transistor insulator
Old 25th December 2002, 01:12 AM   #11
OddOne is offline OddOne
I got the samples in finally (only like three WEEKS later) in the form of two 8.5x11 sheets of 1 mil Kapton 100MT. I'll do a write-up and some basic #s on it in the next few days when I get the chance.
oO
Old 27th December 2002, 03:50 AM   #12
Mark A. Gulbrandsen is offline Mark A. Gulbrandsen
Nelson Pass mentioned in a previous thread that.....
"I like Thermalloy's white thermal grease, but it's kinda messy"
Messy isnt the appropriate word to describe that stuff and I'm not sure there is a word that can! I once had a big tube of it squish out all over the inside of my tool box cause I forgot to place it back in its "safety" container . Man, one daub of that stuff and you can paint your whole house!!
Mark
Old 27th December 2002, 04:55 AM   #13
Hartono is offline Hartono  Indonesia
Default Re: DuPont Kapton MT as IC/transistor insulator
I did use the arctic silver compound + copper heatsink(for smallest possible footprints), the one that form like a glue, for cooling RF amp IC on the CD transport
cool stuff, arctic silver
Old 27th December 2002, 06:48 AM   #14
mrfeedback is offline mrfeedback  Australia
mrfeedback's Avatar
Default Bio Degradable Insulation.....
Philips in the past used a Mylar/Kapton like insulator under the line output transistor in televisions.
In time these fail by darkening and becoming brittle under the middle of the TO-3 device used, and breaking down to the heatsink (peak voltages are over 1000V).
Standard practice is to replace with a mica insulator.
Eric.
I believe not to believe in any fixed belief system.
Old 27th December 2002, 08:19 AM   #15
ALW is offline ALW  United Kingdom
Default Messy Grease
I too hate the white thermal compound, it's ability to spread over the widest possiblwe area, to include my clothes etc. is irritating to put it mildly. It works very well though, with a mica insulator.
A word of warning about some of the alternatives, more than one commercial early adopter of the silicone-based pads experienced significant failure rates from such products in their power amps.
I only use the Kapton-based pads (I use Bergquist ones) and these have proven to be utterly reliable, and have good thermal performance for the higher grades.
I have also experienced failure, after time, of the earlier silicone based pads, the material creeps with time, causing eventual breakdown.
Andy.
Old 27th December 2002, 10:14 AM   #16
Elso Kwak is offline Elso Kwak  Philippines
Banned
Send a message via Yahoo to Elso Kwak
Exclamation Kapton
Hi All,
I have seen some very alarming reports on Discovery Channel about Kapton used as electrical wire insulation in commercial airplanes of Boeing and Airbus.
According to the report when the isolation gets hot as a result of a shortcircuit it spontaneously gets into fire and EXPLODES causing the fire to spread.
For this reason this compound is no longer used in military planes.
For commercial aviation the situation is simply denied by the manufacturers.
In the view of above I would never think about using Kapton as a transistor insulator in my home equipment.
Old 27th December 2002, 11:11 AM   #17
mrfeedback's Avatar
From memory, the cause is brittleness of the kapton insulation, which cracks away when running over hard corners and burrs, and then the further process of burning when overheated.
In heatsink application this failure mode is not a concern.
Eric.
Old 27th December 2002, 03:16 PM   #18
Petter is offline Petter
1. Kapton in power amps should not be a problem. Aircraft failures are typically due to wear and water causing sparcing.
2. The best material for electrical isolation and thermal resistance is Beryllium Oxide which is illegal in many places due to the toxicity of dust if ground. Availability is limited -- but I have seen TO-3 form factor.
3. The second best material is probably the relatively new fired Aluminum Oxide washers. Various form factors are available.
4. If you don't want a mess, consider using SilPad 2000 or equivalent. I bought some of these from Bergqvist. You will not get the performance benefit of reduced capacitance offered by the fired ceramics (2 and 3 above), but you will be much more unlikely to mount the devices wrong and loose performance that way.
5. Thick thermal grease is not recommended -- it is too hard to work with
6. Arctic silver etc. are not recommended as they contain conductive material.
There are further posts on this in the archive if you are interested.
Petter
Old 27th December 2002, 04:19 PM   #19
sam9 is offline sam9  United States
sam9's Avatar
Default Bergquist
The Bergquist web site is:
www.bergquistcompany.com
not as much fun as relating personal experiences/opinions but it does include specs and application notes on all manner heatsink pads including a number of products not even listed in digikey.
DuPont Kapton MT as IC/transistor insulatorHide this!Advertise here!
How to glue Kapton? Wavebourn Planars & Exotics 10 17th December 2008 04:29 AM
Transistor Insulator Sources - US Zero Cool Solid State 21 6th May 2008 02:04 AM
FS 12 micron Dupont Mylar nautilus Swap Meet 3 18th December 2007 11:39 PM
DELTA PA-34A Power Amplifier by Jan Dupont MEGA_amp Solid State 8 21st January 2005 06:30 PM
Q: DuPont Mylar Film for ESLs... Rarkov Everything Else 34 23rd July 2003 11:30 PM
