I have a transformer with the following primary/secondary configuration (see attached pic) . I would like to use this in a dual bridge rectifier power supply per the diagram below (taken from http://zero-distortion.com/start.htm) The goal is 38-0-38. Can I use the 14 and 28 taps on the secondaries to attach to the bridge rectifiers to achieve this result? Thanks for the help!
Z
none |
#2 |
Power supply diagram attached:
none |
#3 |
If both sides of the secondary produce the same current, then just wire it up as in the diagram using only the 28V and 0V legs to each bridge. 28 x 1.414 = 39.59 After losses, you'll be close to the 38-0-38 target.
Two people can keep a secret if one of them is dead. |
| Transformer wiring | Calamaro | Power Supplies | 3 | 3rd July 2009 02:50 PM |
| How to wiring the transformer | olaychang | Tubes / Valves | 7 | 2nd February 2009 05:07 AM |
| I need help with my transformer wiring | onform | Power Supplies | 0 | 1st June 2008 07:43 PM |
| transformer wiring | homertooties | Power Supplies | 3 | 12th June 2007 08:19 AM |
| Transformer Wiring? | Killjoy99 | Parts | 4 | 2nd October 2004 11:00 PM |
| Page generated in 0.08927 seconds (72.65% PHP - 27.35% MySQL) with 11 queries |
