Gidday ppl,
i was asked by another tech today about replacing a 2SB755 /2SD845 with 2SA1494/2SC3858 question is what are the effects of to low or high HFE in an output stage - this is unfamiliar territory for me as i mainly deal in Hybrid Power ICs - Baily
.:Ride the Lightning...Feel the Thunder:. - Technics Triple Thunder www.welcome.to/Technics |
#2 |
Did it Himself
Too high hFE can result in instability but unless it's massively higher it's not usually a problem. Too low on the other hand and you cripple the driver stage (at the very least) and distortion goes up.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
The HFE of the 2SB/D ranges from 55-160 (from toshiba datasheet)
the 2SA/C ranges from 50-180 (from Sanken datasheet)
#4 |
Did it Himself
Those are so close as I'm surprised your even asking really!
fT would be the parameter to watch if voltage and current, SOA are all similar, now you've ruled out hFE.
#5 |
Hi richie00boy,
100 % agree with you! On everything. -Chris |
| which output transistor? | solid | Solid State | 1 | 2nd May 2009 10:23 AM |
| Can bias transistor mount on top(body) of output transistor?? | Leolabs | Solid State | 23 | 16th February 2008 12:35 AM |
| Output transistor substitution | XEAGLEKEEPER | Solid State | 2 | 4th December 2006 12:42 AM |
| Output transistor | jboo8706 | Class D | 2 | 21st August 2006 11:30 PM |
| TV Horzontal Output Transistor for output stage..? | ronybc | Solid State | 46 | 10th October 2005 02:26 AM |
| Page generated in 0.07613 seconds (80.20% PHP - 19.80% MySQL) with 10 queries |
