Electrons are yellow and more is better!
http://www.beis.de/Elektronik/LNPreAmp/LNPreAmp.html
Have you seen this? It's nothing new to use HF or RF transistors as low noise input transistors. Even Elektor had such a design many years back but this german has done a very good article about this.
/Per-Anders (my first name) or P-A as my friends call me |
#2 |
interesting and achieved way below (better than) his already good target. Sounds like it will be worth following to see developments.
regards Andrew T. |
#3 |
Hi folks,
any idea how to activate Uwe Beis' Email?
regards Andrew T. |
#4 | |
http://beis.de/Elektronik/EMail_Beis.html |
#5 |
Thanks Mzzj,
that link worked.
regards Andrew T. |
#6 |
I have read Uwe's directions for emailing and although this is a matter of course, something that is obvious, many people should think more about how the write messages to strangers. The least you can expect is a message signed by the name.
Compare the directions from Rod Elliott http://sound.westhost.com/contact.htm
#7 |
The limitation of this design is the active noise injection from the current sources. Check it out.
#9 |
T3, T5 and T6 sure contribute some noise, I can't tell off-hand though how large the contibution really is. With an undegenerated BJT input (not low-gmish JFET) second-stage contribution can usually be ignored.
Samuel |
#10 |
He should use S/N ratio noise measurement, because input impedance differ the noise, in this kind circuit.
| anyone with a low noise preamplifier circuit for guitar? | winner | Instruments and Amps | 3 | 14th January 2009 06:51 AM |
| Extreme extention?? | mp006ltk | Subwoofers | 6 | 18th December 2004 08:53 AM |
| Help - Extreme Guitar Problem (noise related) | AlvinB | Everything Else | 10 | 3rd December 2003 03:36 AM |
| Extreme DAC 3.0 | martioz | Digital Source | 3 | 11th March 2003 10:45 PM |
| Really, really extreme phono, more extreme than mine | peranders | Analogue Source | 34 | 22nd October 2002 11:59 PM |
| Page generated in 0.10210 seconds (76.87% PHP - 23.13% MySQL) with 10 queries |
