Old 18th May 2006, 05:40 PM   #41
Default cyrus 2 capacitor
hi
is the capacitor i have linked to below the required type
http://www.maplin.co.uk/Module.aspx?...itors&doy=18m5
just to make sure i have the right one.
I have a pic of the underside attached and as you said there is a + sign so side closest to edge is positive.
Thanks for the help
Old 18th May 2006, 05:53 PM   #42
Did it Himself
richie00boy's Avatar
The track breaking points to another fault as well as the cap. Really you need to trace where the track connects to. This is where the schematic comes in handy. If you tell me if you have issue 6 design (pushbutton mains switch), or issue 7 (toggle mains switch) I can put the appropriate schematic up.
Can't really coment on the cap, need to check the pin spacing.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 18th May 2006, 06:14 PM   #43
hi
the unit is powered on by a push button on front panel ( with led lighting the cyrus2 letters on front panel ).
thanks
Old 18th May 2006, 06:55 PM   #44
Geoff is offline Geoff  United Kingdom
Default Re: cyrus 2 capacitor
Originally posted by atomised
hi
No, far too large! 4700uF rather than the required 470uF.
Try this page instead:
http://www.maplin.co.uk/Module.aspx?...ce=14&doy=18m5
You will probably need to go for the 470uF 100V to get the right lead pitch.
Old 18th May 2006, 07:17 PM   #45
Did it Himself
Has the output stage got a pair of TO220 devices per rail (total 8 devices), or a single TO247 per rail (total 4 devices)?
Old 18th May 2006, 07:27 PM   #46
anatech is offline anatech  Canada
anatech's Avatar
Hi atomised,
I've seen that trace go on other Cyrus 1 products.
Please check for a shorted diode, that would explain the exploded cap as well. A 63 V capacitor should be close enough in pin spacing. That is the value I use for replacement. Use a piece of insulated wire to replace the burned track, cut away all the loose trace.
Any short in the supply from that capacitor could also cause the burned trace. Do not fail to replace the 22 uF caps (I thought they were 10 uF - sorry) and replacement of the regulators may not be a bad idea. I know they were running hot (they all do).
That should put you back in fighting trim.
-Chris
Old 18th May 2006, 07:56 PM   #47
Hi Anatech,
I went daft with Ebay a year or two back and now have a lot of secondhand nearly modern Cyrus gear. I'll not list it, but I have a couple of eights and no Xs.
regards Andrew T.
Old 18th May 2006, 08:04 PM   #48
anatech's Avatar
Hi Andrew,
So, what do you think of the sound?
-Chris
Old 18th May 2006, 09:32 PM   #49
Chris
Sorry to disagree with you but modern 50V and 63V 470uF capacitors have a lead pitch of 5mm. The older 16mm dia cans used in the Cyrus 1/2 have a lead pitch of 7.5mm which is why I suggested atomised went for a 470uF 100V which also has a lead pitch of 7.5mm.
That is of course assuming that one wishes to match the lead pitch rather than splaying the leads and mounting the capacitors further off the board.
Geoff
Old 18th May 2006, 09:40 PM   #50
lohk is offline lohk  Europe
lohk's Avatar
The burned broken track routs both caps to the star ground (which is between the main power caps), so it is very likely one of the diodes (close to the cap) broken also. The orientation of the cap is - maybe already mentioned - with plus outwards. Both caps should be changed, that is pretty obvious.
An Cyrus 1 from this bunch (small transistors) can easy be changed into a Cyrus 2 (power amp only) by adding another 4 output transistors, adding another 4 drivers (ZTX753/653), all other parts are on the board already. I forgot the infos about the bigger transformer.
I did not remember a sensational big difference in sound to a Cyrus 1, but I only have one Cyrus 1 left in my collection.
/alohka/
WTB Cyrus 1 or Cyrus 2 amplifier monstertrucker Swap Meet 0 20th November 2008 01:04 AM
Cyrus 3i Juko Solid State 10 1st June 2007 07:45 PM
Trying to fix my Cyrus II amp karl.s. Solid State 9 18th September 2005 02:07 PM
Want: Cyrus Lid richie00boy Swap Meet 0 27th April 2005 12:39 PM
cyrus 7 and 8 honsten Solid State 2 15th February 2005 10:26 PM
Page generated in 0.20056 seconds (86.97% PHP - 13.03% MySQL) with 11 queries
