Old 17th May 2006, 08:02 PM   #1
Default quad 44/405-2 another hum problem
I have a quad 44/405-2
It has been upgraded with modified boards and output transformers, and a dual mono power supply.
I think i have a problem with the 44 though.
It makes a dirty sounding hum, but only at high volumes with all sources unplugged, the sound is different/louder/quieter depending what source is selected.
Does anyone know this equipment well enouigh to say whats the likely cause?
Its not much of a problem because i never listen to it that loud anyway, but all the same, something aint right.
Im pretty sure its not the power amp as its only just been sorted and is dead silent without the pre linked up.
I hadnt used the pair much, or checked for hum at high volume before the power amp was modded.
Any ideas?
Old 9th June 2007, 06:46 AM   #2
Ketalar is offline Ketalar  France
Default Re: quad 44/405-2 another hum problem
Any ideas?
Same problem here but only with tape (both) and phono inputs.
Curioulsly, it appears after around one minute, as if a capacitance slowly charges.
I've read somewhere that in early '44s chassis ground was not connected to mains ground. Dunno if it helps.
Old 9th June 2007, 07:25 AM   #3
Quad would not do this.
regards Andrew T.
Old 23rd June 2007, 07:46 AM   #4
Sure.
I should have written that there could have been different ground connection methods between early an late '44s...
Anyway, this peculiar hum problem exists.
The input cards are connected to a board where also sits the PSU elements (except the transformer), maybe one of them radiates ?
Old 23rd June 2007, 11:28 AM   #5
Here's what I found :
http://db.audioasylum.com/cgi/m.mpl?...ns&r=&session=
Maybe it could help.
Best regards,
Old 23rd June 2007, 11:36 AM   #6
Hi Ketalar,
are they referring to Quad11 or 44 or 405?
regards Andrew T.
Old 24th June 2007, 06:36 AM   #7
Originally posted by AndrewT
Hi Ketalar,
(My english may be poor)
Hello,
Thanks for the reply.
They refer to QUAD II fed by a 44 :
He writes the II has no ground connection, except via the signal lead.
In my opinion, it means that its power cord has only 2 wires, no mains ground wire.
In this case (!), if the 44 signal output ground is not connected to the mains ground, this leaves the amp floating and "hot". Idem for the inputs.
I will check my preamp, to see if my hum problem is solved by connecting (or not) signal gnd to mains gnd. However, as my 44+405 have 3-wire power cords, that would add a ground loop and worsen my hum problem !
Old 24th June 2007, 08:41 AM   #8
This quite normal and generally does not give rise to hum.
Many manufacturers can get this right and I have heard this combination and I cannot recall any hum.
regards Andrew T.
Old 6th July 2007, 06:49 AM   #9
I checked my '44 : the audio gnd and mains gnd are not connected together, as per the schematics, by the way.
Voltages on input cards pins are OK, but I dont'have a 'scope to investigate further.
As the hum problem arises from only 3 on the 5 inputs, I wonder if some 4066 could be defective...
Is it possible ?
Quad esl 63 problem howes hound Planars & Exotics 14 31st August 2009 05:40 PM
quad 606 mk1 problem kokheng Solid State 2 4th February 2009 01:26 AM
Quad 405 hum problem vzs Solid State 16 7th June 2006 09:26 AM
Quad ESL 63 problem. Please help DirkD Planars & Exotics 9 4th October 2005 02:03 PM
Quad FM4 problem JDeV Solid State 4 28th November 2004 08:04 AM
Page generated in 0.10624 seconds (81.54% PHP - 18.46% MySQL) with 10 queries
