Bad transformer rewinding
Old 17th May 2006, 10:21 PM   #11
VEC7OR is offline VEC7OR  Lithuania
VEC7OR's Avatar
I think that its now worth it.
Time you spend rewinding it will probably buy you a new one, especially it itsa small one.
Profanity took a very interesting form in Russia where there exists a language of sorts, most of its words based on four basic profane roots - nouns p...is, wh.0.e, c..t and verb f..k. It is possible to sensibly communicate using just these four basic roots.
Old 17th May 2006, 10:55 PM   #12
anatech is offline anatech  Canada
anatech's Avatar
The thermal fuses have opened.
Question is ..... why? I know, do you?
Give Denon a call and price those transformers. Do you have the part number printed on the outside? Could be 233 .... and so on.
-Chris
Old 18th May 2006, 07:07 AM   #13
R.I.P.
Is it worth repairing?
The Orientals started the trend of throwing things away after six months by releasing the new super dooper version.
regards Andrew T.
Old 18th May 2006, 07:18 AM   #14
ostie01 is offline ostie01  Canada
Part number on transformer are:
2336188005
TKP0278-E93
6 742
Where is located the fuse on a transformer
Since it's dead. just begun to open it up to see inside, not finish yet but I'm on the way.This is weird, no sign or smell of burning
Old 18th May 2006, 07:58 AM   #15
R.I.P.
if a thermal breaker is fitted it will more likely be under the secondary winding.
If the windings are on separate spools, it could be under the primary insulation or buried in the primary winding.
These thermal fuses are not intended to be easily repairable/replaceable due to the damage to insulation that is likely at the high temperature that causes the thermal to eventually trip.
Another case of throw it away ideology.
regards Andrew T.
Old 18th May 2006, 08:46 AM   #16
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Just get a new one. You will damage some of the laminations trying to get them apart, if you manage at all. The whole thing is soaked in varnish so must be solvent dipped to clean it off you you will simply be fighting all the way and ruin it.
And if the secondary has been wound over the primary it's lot of work, you'll probably need a helper if you don't have a winding machine as well.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 18th May 2006, 09:08 AM   #17
WOW. much more complicated than I thought. Wrote an e-mail to denon to have the cost for two brand new transformer. Will depend on the price, else will salvage the 3 amps. One transformer still good so I have one power amp at 120w. and two board which I could find an old transformer with approx. 45v 0 45v to go with the two remaining boards. As always, thanks for your help.
Old 24th July 2017, 09:34 PM   #18
ampexperts is offline ampexperts  United States
ampexperts's Avatar
In my experience, the hardest part is taking apart the core so one can get the bobbin assembly out for rewinding. I gather that takes special tools which I don't have.
Mark A. Weiss, P.E.
www.ampexperts.com
Old 24th July 2017, 10:53 PM   #19
mchambin is offline mchambin  France
Originally Posted by Bazukaz View Post
Having no ideas how toroid winding machines look like....
The machine is mosly clever.
One can build this kind of machine from a bicycle wheel rim.
Transistor junction temperature is not transistor case temperature.
Old 25th July 2017, 03:40 AM   #20
anatech's Avatar
This thread is from 2006!
-Chris
"Just because you can, doesn't mean you should" my Wife
Bad transformer rewindingHide this!Advertise here!
Transformer rewinding material elseif Parts 2 5th September 2008 12:30 AM
Rewinding Power transformer ThSpeakerDude88 Tubes / Valves 11 27th August 2007 02:07 AM
Rewinding Microwave Transformer 6502dude Power Supplies 5 3rd April 2005 04:06 PM
Transformer Rewinding JhonDoe Parts 3 1st March 2005 12:15 PM
Rewinding a Toroid transformer hifi Parts 8 6th September 2001 12:50 AM
