Old 15th May 2006, 04:44 PM   #1
Default GA28F Mosfet Amp
Hello All,
I am still new to this forum but am now asking a few questions.
I got given a GA28F 100W mosfet module awhile ago now, i spent some time looking at it and decided it wouldnt be to hard to copy it. So it did! I took a photo of the under side of the PCB, put it into photoshop, worked it out and then etched my own PCB, I have populated it and its tested and working.
I now have two 100W mosfet modules. I am not sure what to do with them!
I have put it all together in a box and tryed it out runing in bridged as a sub amp. However it wasnt that loud!
The power supply I used is a 35 0 35 @ 160VA toroidal. From what i have read this isnt enough to drive two of the modules. I have put together seperate rectifiers and caps for each module but they share the PT.
I do however have an other toroidal not the same make though but is 35 0 35 @120VA. How much would it improve things if i use a seperate PT for each module? Even though they are different VA ratings?
I dont have enough cash to buy a new 500VA PT . But i do have another transformer in a Toa TA-957 (PA) that i could use but i have no info on it.
Any ideas on what to do?
Thank you for reading.
Old 7th October 2006, 05:59 PM   #2
Default Bridging amps
To bridge 2 GA28F ampls you need to invert the input signal to one of the module, that way when one output is positive the other is negative, this give you twice the voltage swing. You must connect you speakers between the two outputs of the modules and not to ground.
Anyproblems let me know.
Old 8th October 2006, 04:00 AM   #3
I am greedy for schematics,
Can you post the schematic? Or even tihe pcb?
Tks a lot.
Old 8th October 2006, 12:18 PM   #4
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
BP,
Study schematics instead of only collecting,the GA28F is the Maplin Mosfet kit.
(the largest electronics store chain in the UK)
Several variations of the 150W design have been posted on diyA.(including the 1987 original and 1990 update)
Looks like Sponge Bob has killed another thread.
Old 5th May 2007, 12:43 AM   #5
Hi!
You may be the only preson in this world who can help me, and may be I also can help you wit your amp?
I have a Mosfet amp. 2x100W, but by a mistake I bave distroid three resistors on both chanals. I want to replace these, but the problem is: I am not able to reed the value on them(they are burned). But may be you have a circuit diagram that shows the value of R7, R11 and R15?
Can you help me?
Dag in Norway
Old 5th May 2007, 01:11 AM   #6
jaycee is offline jaycee  United Kingdom
If it's the MOSFET amp I'm thinking of (one pair of outputs on an L-bracket), then it's basically just Hitachi's application note for those outputs.
Old 5th May 2007, 01:58 AM   #7
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Schematic pls??
Old 5th May 2007, 03:57 AM   #8
Maplin 150w MOSFET regulation?
Schematic:
http://www.cpemma.co.uk/map_100w.html
RAS-300 Mosfet Amp. Eugenio70 Solid State 86 10th December 2011 03:05 PM
BiCMOS Bipolar+MOSFET better than MOSFET lineup Solid State 5 8th December 2009 11:46 AM
maplin mosfet GA28F upgrades? Gravenstede Solid State 5 17th March 2008 06:34 PM
MOSFET/MOSFET amplifier jarek Pass Labs 21 22nd June 2004 05:04 PM
MOSFET's peranders Swap Meet 2 24th November 2002 10:11 PM
Page generated in 0.09410 seconds (74.75% PHP - 25.25% MySQL) with 10 queries
