I have seen a couple of companies online that produce very high voltage amplifiers (on the order of +/- 1kV output swing).
One such company is Trek Inc. www.Trekinc.com In their brochure, they give a block diagram as to how their product works, and if I may summarize it, the output stage is a bunch of cascoded mosfets (with a very high voltage bipolar supply) with each mosfet gate driven from an optoisolator. ==> I thought optoisolators were nonlinear; how can an output stage be driven from an optoisolator with the signal integrity still preserved? |
#2 |
What use is it for you?
Their biggest model can only put out 400mA at ±1KV. "Large Signal Bandwidth (2% Distortion) DC to greater than 2.5 kHz." "Small Signal Bandwidth (-3dB) DC to greater than 20 kHz." Model 30/20A High-Voltage Amplifier I use an AR Inc unit at work that can do ±15KV, but at only 3.5mA There are some class D amps with IGBTs that can do ±1KV at several KW, maybe that's what you need? |
#3 |
snip: rtarbell
==> I thought optoisolators were nonlinear; how can an output stage be driven from an optoisolator with the signal integrity still preserved? Simply use feedback! More serious is that they are noisy! snip: djk Their biggest model can only put out 400mA at ±1KV. Trek is THE company for high voltage amps: http://www.trekinc.com/products/+5kV.asp http://www.trekinc.com/products/5-80.asp for example! Regards Heinz! |
#4 | |
regards, Gerhard |
#5 |
Check out size and weight of model 5/80 (the one from second link)
I use to feel like the small child in The Emperor's New Clothes tale |
#6 |
[QUOTE]Originally posted by gerhard
[B] That moves the problem from the forward to the feedback path only. No, because the FB-path is DC-coupled the whole amp get much more linear, but the noise is still there. Regards Heinz! |
#7 | |
need an opto coupler for the forward path in the first place? regards, Gerhard |
#8 | |
Gerhard, I don´t need it but they use it On the other hand if noise is not the issue I think also that this is a simple way to steer a long chain of c 1200V N-igbts/mosfets EQUALLY at high slewrate! Regards Heinz! |
#9 |
electrocuted by the output of an audio amp....what a way to check out, eh?
All the trouble I've ever been in started out as fun...... |
#10 |
I know that these high voltage amps are not exactly audio quality, I was just wondering how to drive an output stage using optoisolators. How would they be connected?
| output stage with high impedance | alex0 | Solid State | 54 | 1st November 2011 05:40 AM |
| Differential output stage: cap voltage? | Klimon | Tubes / Valves | 2 | 23rd May 2009 11:44 PM |
| Tube output stage for voltage DAC ? | mgm31 | Digital Source | 9 | 5th February 2008 08:22 AM |
| Which high power CCS for output stage? | andyjevans | Tubes / Valves | 12 | 24th November 2005 11:45 AM |
| High voltage transistors for VAS stage | rtarbell | Parts | 4 | 15th November 2005 12:13 AM |
| Page generated in 0.12340 seconds (79.91% PHP - 20.09% MySQL) with 11 queries |
