Hi, guys,
I am trying to fix a fender m80 solid state amp. It works, but there is one section of the board that is literally burning hot. If you would please look at the partial schematic, my problems are resistors #94 and #95, and zener diodes CR 25 and CR 26. All the other resistors, diodes, and caps test OK (I think I know what I'm doing ). All the voltages are OK. No other components on the board are even warm. I've replace the four components (although I had to put in 1N5352 instead of the original 1N5353 zener diodes), and the problem is still there. I'm assuming that there aren't supposed to be burning hot components on the board!! OK, I've thrown down the gauntlet...please help!! |
#2 |
NORAA,
Looking at the power ratings of the resistors and zeners (5W) it could be normal behaviour. If possible, I try to mount them elevated from the PCB or at least resolder them. What current is running trough the R's? /Hugo |
#3 |
Hi NORAA,
Yup, they will be hot as heck. 50 V (ish) dropping to 16 V through a 330R resistor means the diode will dissipate 1.65W with no other load connected. The resistor will always dissipate 3.5 W. That is very hot. How much is the current draw from the op amps? I'll assume that is all that the circuit supplies power to. A voltage regulator stage might be more intelligent. -Chris Edit: Hugo, just over 100 mA. C48 and C49 should be rated at 63V. They may be opening up by now. |
#4 |
Most 5W resistors de-rate to zero at 250*C, some are 275*C.
This would indicate an operating temperature at 3.7W of about 185*C, enough to cook the board and melt ordinary solder. |
#5 |
Hi djk,
Exactly. I wonder who designed this one. Oh, ° (ALT-0176) -Chris |
#6 |
you guys are amazing...since this is a Fender amplifier, for a company in business for around sixty years, I thought for they knew what they're doing, and I was sure there was a problem with the amp....I guess a problem in the design stage is a problem with the amp....
Well, if I was an electrical engineer, I don't think I would design a amp circuit that could double as a frying pan!! thanks a zillion.......... |
| A75 protection diodes and Cascode load resistors | slogan2112 | Pass Labs | 1 | 13th October 2008 10:10 PM |
| Resistors Diodes etc in Toronto? | Grahamt | Multi-Way | 3 | 8th March 2005 02:27 AM |
| Phono Socket Hell | Pbassred | Solid State | 5 | 9th January 2004 12:12 AM |
| First Gainclone (Hell, first amp...) | Llamas | Chip Amps | 48 | 19th September 2003 03:47 PM |
| What the hell is that ??? | nar | Pass Labs | 21 | 10th May 2002 06:11 PM |
| Page generated in 0.08296 seconds (78.12% PHP - 21.88% MySQL) with 11 queries |
