Hi everyone,
I'm looking for SONY TA-FE530R amplifier schematics or any information about its power supply. Thanks. |
#2 |
What's the problem with it?, the PSU is a conventional CT transformer and bridge rectifier, although there is a second single winding, with a bridge as well (made from seperate diodes).
Nigel Goodwin |
#3 |
thanks for your reply, I try to find this schematics because i'm gonna buy this amplifier on ebay (psu problem). |
#4 | |
However, Sony's do have unreliability problems with mains transformers, because they tend to buy cheap chinese ones which are often too small for the job. As it has two windings you would probably need two transformers to replace it, or buy the correct one as a spare - but they are STUPIDLY expensive from Sony (this assumes the transformer is faulty of course!).
Nigel Goodwin |
#5 |
Yes you're right,
maybe the seller pointed the wrong direction. By the way, i'm gonna replace the power stage (2*stk modules) by 2 hexfet power stage rated at 100WRMS/4 ohms. The main transformer will be replaced by a toroid one. |
#6 |
From a TA-FE520R
Hope this helps regards James |
#7 |
you can download it for free at www.sharefx.com until the
12. mai , I uploaded it. If you want to support this marvelous site you can donate 5 Dollars and get permanent access for one month. cheers |
| schematics sony Ta- F6B | max29 | Solid State | 5 | 17th March 2011 07:36 PM |
| Schematics SONY CDP-791 for upgrade | CJAVIER | Digital Source | 4 | 10th August 2010 09:37 AM |
| Help needed ! Inter M R300 schematics needed ! | alexclaire | Solid State | 30 | 9th September 2009 06:14 AM |
| Sony Schematics | enzedone | Solid State | 5 | 12th January 2007 10:22 AM |
| Sony CDP228ESD schematics needed | beauty_divine | Digital Source | 0 | 10th November 2006 07:16 PM |
| Page generated in 0.09407 seconds (72.82% PHP - 27.18% MySQL) with 11 queries |
