Old 7th May 2006, 09:28 PM   #1
DreadPirate's Avatar
Default HK330A Doesn't Want To Do Stereo
This H/K receiver is acting funny FM-wise. The signal strength meter is dead in FM, but only in FM, it works fine in AM. In addition, channels come in fine in FM mono and when you switch to FM stereo, the signal still comes in on mono (no stereo) and I have a good antenna. The FM beacon glows dimly and continuously when the unit is on and in all modes The schematic can be found here:
http://www.eserviceinfo.com/download...rdon_330A.html
Scroll down a bit for the link just under the "Download Restrictions" box.
Using a good viewer like Brava, the schematic is readable, I have found other viewers are finicky with .TIF files.
The only measurement I have made so far is at the stereo/mono switch, I get 104K Ohm in stereo and 0 Ohm in mono.
Any comments appreciated.
Old 10th May 2006, 03:48 PM   #2
latala is offline latala  United Kingdom
The hk 330A uses a discrete switched envelope decoder that is not mono /stereo compatable. Hence you will get no output on stereo if the 38 khz carrier is not being generated.
Do you have a scope?
If so trace the pilot 19 khz tone and then through the frequency doubler to 38 khz
First suspect the freq doubler transistor
I have had these fail in the past
regards Trev
Old 10th May 2006, 06:50 PM   #3
Thanks trev. No I do not have a scope. Which transistor is the frequency doubler?
Old 10th May 2006, 07:24 PM   #4
This might help, Replacement Parts List:
http://img128.imageshack.us/img128/6...rtslist0km.jpg
Old 10th May 2006, 09:06 PM   #5
Shame about the scope! can you not loan one as its difficult without
The transistor you are looking for is tr303 a 2sa49
however any general purpose small signal PNP transistor should work
regards Trev
Stereo in/multiple Stereo outs Circuit MartinByrne Everything Else 3 7th May 2009 01:11 AM
Reprocessed for stereo, Rechanneled for stereo and Duophonic oldheathkitphil Analog Line Level 3 29th February 2008 01:20 PM
HK330A Stereo Beacon Issues DreadPirate Solid State 6 9th December 2007 05:32 PM
HK330A STILL Doing The Mono Thing DreadPirate Solid State 7 1st October 2007 05:08 PM
Page generated in 0.08824 seconds (83.34% PHP - 16.66% MySQL) with 10 queries
