Hello,I wonder if the dis pre is a right match for the mosfet power follower...
I am very intrigued for the sound of a power follower.... Have someone try it? Thanks for all Best regards |
#2 |
and how to implement a volume pot inm the macura dis pre?
Thanks to all |
#3 |
Hello sopapo,
this should work fine together. Regarding volume pot - please see the 1st image on this page: http://web.telecom.cz/macura/dispre_en.html The volume pot, preferably low impedance like 10k or 5k, is just at the input of the preamp circuit. There was a number of people who have built a power follower, maybe if you perform search you may find some posts for example here: Mosfet power follower (Pavel Macura) Have a fun with these circuits. Best regards, Pavel Macura |
#4 |
Regarding Dispre - I have built and sold 15 units, as assembled PCBs. Here you can see the casework implementation of one of my customers:
http://audio.kvalitne.cz/dispre/dispre.htm |
#5 |
Hi Pavel,
what I like in your design is the use of those 0,02 EUR Transistors. I see that you don't use LEDs in the current sources (Q4/Q7) Does it sound better with R15/R18, are there additional reasons? Same question goes for the FC (Q3/R38/R42) Did you try to use seperate Voltage reg's for the two stages (left and right from R44/C11)? thanks in advance, Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog |
#6 |
Hi Rüdiger,
in case of this preamp I decided to make it fast and very simple. There was no special intent how to design the current sources. For the reason of their solution and for the reason you mentioned, this preamp needs a decent, very low ripple power supply. C11 and C14 are pretty big, 1000uF. There is also an image with component values on the web page. Regards, Pavel |
#7 |
Pavel
Why do you use BD139/140 for output stage? Aren't they a bit old? |
#8 |
Hi darkfenriz,
you are right, they are old and it would be possible to find better devices. 139/140 are just easy to get and cheap. I may try 15030/15031, but am not able to promise when. Regards, Pavel |
#9 |
No, he's not banned, he can post any time he wants. But the new user name he came up with above, (no, I wasn't fooled), is now blocked.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#10 |
The fact that another member wrote from the computer at my facility does not mean that I have 2 user names. I also write my posts from at least 2 different IP addresses. Do not block OPA2, there is no reason to do so.
| Pavel Macura's MOSFET Power Follower | soundNERD | Solid State | 25 | 24th February 2011 03:23 PM |
| Power Follower (P.Macura) some question? | bezobraznia | Solid State | 61 | 24th November 2005 12:20 PM |
| Mosfet power follower (Pavel Macura) | naim35 | Solid State | 8 | 22nd January 2005 10:51 PM |
| Page generated in 0.09874 seconds (77.24% PHP - 22.76% MySQL) with 10 queries |
