Old 5th May 2006, 06:05 PM   #1
coffin is offline coffin  Taiwan
coffin's Avatar
Default A modified MF E10 amp
Hi
This is a FREE pcb from China, according to the webmaster, this is modified from MF E10....
and I took a while to put it together, using my own stock, except the a few resistor and transformer. So a free PCB with my inventory, very cheap......
This is the whole top view
One channel
Using MJW0281/0302 as power BJT
It seems that MF like to use Jamicon as filtering caps....immitation
MUR860 as bridge
I put it in a integrated case, so add a ladder step att
Changing LED bias R19 to 2SK246
mount the bias BJT on power BJT
The supply of voltage amp stage is MINI Regulator
The look of the int amp
A very beautiful sound....nice and easy....bass is a little bit less
Very musical one.
cheers
Coffin
Old 5th May 2006, 06:19 PM   #2
edl is offline edl  Hungary
edl's Avatar
Hi Coffin,
I like your new amp, nice work!
As I see, you were using so high quality components!
On the margin the schema reminds me MikeB's Symasym...
http://www.lf-pro.net/mbittner/Sym5_...ymasym5_3.html
All the best,
Old 6th May 2006, 03:30 AM   #3
coffin's Avatar
Originally posted by edl
Hi Coffin,
All the best,
Hi
Just got those "high quality components" in my stock, so...why not using them?
Yes I think the topology is very identical.....except PNP not NPN
cheers
Coffin
TA-10.1 vs Modified SI Davet Class D 0 19th March 2007 07:05 PM
IC: Looking to get my T-Amp modified cmirza Swap Meet 0 29th May 2006 06:19 AM
ME2 modified MJS Multi-Way 7 20th October 2005 03:41 PM
modified mid-fi? amo Multi-Way 0 10th June 2003 01:21 AM
Can This Amp Be Modified??????? OMNIFEX Solid State 4 11th April 2003 02:37 AM
Page generated in 0.08762 seconds (71.35% PHP - 28.65% MySQL) with 10 queries
