Old 22nd November 2002, 01:22 PM   #1
Default BC546 A or B in P3A
I'm rebuilding my P3A, and i have both BC546A and BC546B home, which ones should i use? The only difference i can spot is the hFE values, with the B-version being slightly higher (200/450 vs. 110/220).
Old 22nd November 2002, 01:37 PM   #2
halojoy is offline halojoy  Sweden
On Hiatus
Default Nelson prefers high beta.
And highest beta have 546 C, then B then A
So if you can find 546C, use them
If not 546B will work as good
Old 22nd November 2002, 01:44 PM   #3
UrSv is offline UrSv  Sweden
UrSv's Avatar
And what Rod Elliot prefers we possibly don't know.
I guess that the B version would be preferable as it seems discussions elsewhere seems to suggest that high beta is preferable in diff pairs. I might be wrong though...
/UrSv
Old 22nd November 2002, 04:39 PM   #4
Jean is offline Jean  United States
Jean's Avatar
Send a message via AIM to Jean
I asked Rod similar question, I wanted to use 546b because I run out of A's. He replied "make sure that the input stage especially uses the same type, so as to minimise the voltage differential at the input (for minimum output offset voltage)."
Seems to work just fine with both.
Old 22nd November 2002, 11:16 PM   #5
Great, i'll go with the B's then.
Here is the PCB i made for it:
http://daviruz.homelinux.org/pics/amp/poweramp.png
Any opinions?
which is the echivalent of BC546 in SMD? nbcd Parts 1 30th April 2003 04:15 PM
bc546, 556, bd139 sources/replacement help Mattyo5 Parts 4 6th March 2003 08:04 PM
P3A amp - BC546 Placement dine1967 Solid State 9 3rd January 2003 12:39 PM
Page generated in 0.11200 seconds (60.29% PHP - 39.71% MySQL) with 10 queries
