Hi, all
I have a couple of 8 year old pioneer car amps which I use for a fully active system. they are bipolar output class AB (high biased, class A to around 10W), not bad sounding overall. I want to do upgrades to make them much nicer, and one has a small problem. the problem is gain changing with ambient temp. by about 0.2dB/degreesC. this screws up my imaging depending on the weather. the op-amps are NJM2068S. I was looking at either NE5532 or OPA2227/8 and making little boards to suit (the NJM are a 9-pin SIP). any recommendations? also, I will be by-passing all the built-in eq controls. is it worthwhile to replace the output transistors, they are 2SC5101 driven by 2SC3421 in the +ve, and 2SA1909 driven by 2SA1358 in the -ve side. Where in melbourne (australia) can I get blackgate caps? (for the power supply and signal) any suggestions will be appreciated
Digital is only on or off |
| temp drift in MOSFET Vgs | SemperFi | Solid State | 6 | 29th June 2006 04:50 PM |
| Adding ambient rears ~ from stereo material | rick57 | Everything Else | 16 | 25th May 2006 09:48 PM |
| Small temp voltage on phono input-problem? | trombone | Tubes / Valves | 4 | 19th January 2006 06:24 PM |
| Low Temp Drift VRef (Zener?) | Kashmire | Solid State | 3 | 13th January 2004 01:32 PM |
| ambient release | human prototype | Tubes / Valves | 1 | 30th July 2001 10:57 PM |
| Page generated in 0.06436 seconds (67.44% PHP - 32.56% MySQL) with 10 queries |
