Speaker cable in amp feedback path
Old 22nd November 2002, 06:09 PM   #11
jam is offline jam  United States
jam's Avatar
Carlos,
True but by a different amount. They wired a large value resistor across the fuse so that if the fuse blew you would have some amount of feedback to manintain dc stability. The end result is the same, to take the feedback close to speaker as possible on the assumption that feedback would reduce all non-linearities caused by wire, fuses etc.
Jam
Old 22nd November 2002, 06:20 PM   #12
alvaius is offline alvaius  Canada
Unlike a 4 wire resistor measurement though, my feedback connection in this case must have a bandwidth that extends beyond the audio bandwidth. Any noise picked up on the return path essentially gets reflected to the input and becomes noise at the speakers.
If you were bi\tri amping with electronic cross-overs it may offer an improvement, however, the impedance of the inductors and capacitors in the speakers is likely far higher than the cables connecting to them.
Just some thoughts...
Alvaius
Old 22nd November 2002, 06:58 PM   #13
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Default Re: Speaker feedback
Originally posted by carlmart
This arrangement was suggested by Richard Marsh, in The Audio Amateur 3/85.
The speaker feedback was implemented through a 0.15ohm resistor.
This approach has been around a long time for turning an
amp into a constant current source or otherwise raising it's
output impedance.
But it is not the same thing as discussed above. I believe the
thread is addressing the means of enclosing the cables in a
feedback loop so as to lower their impedance.
This is not difficult to do as long as the circuit is very stable
otherwise and the amount of feedback around the cable
is kept at modest levels.
Old 22nd November 2002, 11:25 PM   #14
traderbam is offline traderbam  Europe
traderbam's Avatar
Why not eliminate the speaker cable?
Old 23rd November 2002, 06:36 AM   #15
Morello is offline Morello  Sweden
Are nonlinearities in cables a real-world-problem?
The distortion magnitude is probably in the -170dB-range.
Best regards\Morello
Audio design engineer. Commerical amplifiers: O&G Engineering RS2000 and Holographic Audio AMP-27 among others.
Old 23rd November 2002, 08:17 PM   #16
Jimmy154 is offline Jimmy154  United States
Jimmy154's Avatar
Default Hi alvaius,
Sorry that this has nothing to do with this thread. But I haven't heard from you about your G4 x-overs for 3 weeks. How's it going with the x-overs? Somebody e-mailed me a little while ago about building some G4's and he says that Graham says that the 10 db spike at 3,750 Hz goes down to 2 db after 200 hours break in although I have noticed this I think. Just wanted to tell you maybe this will and you and later also myself.
Old 23rd November 2002, 08:47 PM   #17
nemestra is offline nemestra
nemestra's Avatar
Default Other British outfit
Don't think that DNM have ever used a feedback loop containing the speaker cable. The other British outfit that Werner is referring to is Deltec - unfortunately no longer in existence. They specified their own speaker cable - Black Slink. This was a well regarded Goretex dielectric cable.
James
Speaker cable in amp feedback pathHide this!Advertise here!
cheap cat5e cable for speaker cable fishline Full Range 6 19th May 2009 07:42 PM
DC blocking cap in feedback path or DC servo? roender Solid State 27 19th September 2007 09:40 AM
Transformer on feedback path NIC1138 Solid State 3 9th May 2007 06:41 AM
problems with speaker cable as power cable pjpoes Parts 11 14th January 2007 08:24 PM
Cheaper path to speaker quality? walker Multi-Way 29 29th October 2002 12:55 PM
