Simple amp is a radio , what to do ? - diyAudio
Old 1st May 2006, 03:19 AM   #1
Default Simple amp is a radio , what to do ?
Built this amp for a small practice amp for guitar but it is picking up the local radio station when turned on . What do I need to do to block the radio station ?
Radio tower is about 1000 yards away clear line of sight.
http://www.runoffgroove.com/littlegem.html
Thanks for any suggestions.
Timothy
Old 1st May 2006, 04:36 AM   #2
Use RC (1K and 390pF) filter at the input, put the amp in a metal box and use shielded cable for connecting the input signal.
Gajanan Phadte
Old 1st May 2006, 03:13 PM   #3
Thank you , right now it has the shielded cable and is just the pcb mounted inside the wood cab in a seperate compartment from the speaker .
Timothy
Old 6th May 2006, 11:30 AM   #4
Rahul is offline Rahul  India
Send a message via Yahoo to Rahul
HI!
Put a 1Mh RFC at the input and ground 560pf from both the end.
We can make it work
Simple Simple SE questions nodiak Tubelab 57 2nd February 2010 11:02 PM
Simple, SIMPLE Digital volume control -_nando-_ Digital Source 5 21st December 2006 01:20 PM
A simple question from a simple man. inteificio Solid State 5 17th October 2005 03:00 PM
Simple (or not so simple) decision wxn Chip Amps 4 5th November 2004 09:55 AM
Simple answer required for a simple question... rabbitz Multi-Way 4 31st August 2003 10:05 AM
Copyright 1999-2017 diyAudio
