Old 30th April 2006, 02:23 AM   #1
Default Yamaha M-80 Mods FINISHED! GOLD!!!
Hi!
I gave in... It was sitting on my floor waiting to be sold, but begging to be worked on. Took 3 solid 12 hour days (not including the parts shopping spree), and has turned out quite well.
Trying to remember all the work I did...
1) Gold binding/bananna posts have been added. Mounted on a very strong anodized black aluminum plate.
2) Twisted feed line length to relay board has been reduced
3) Speaker feeds connected directly to the relay posts! Not through more traces.
4) Yamaha uses different relays for different outputs, so relay 1 cleaned, relay 2 replaced with relay 3 (unused) (relay 1 is supposedly an arc reducing type, relay 2 has gold plated contacts; don't ask me why they chose to do this)
5) Speaker posts A and B are accessed by switch (C is disabled; why connect in series patched through another relay???). Posts C are hardwired in parallel with B, that way if you want to bi-wire... easy!
6) Removed the dried up rubber insulation sheet on the top of the transformers. A possible option to replace in the future if desired.
7) The enclosure may still be a bit scratched up (not my fault; previous owner), but the guts are nice and clean now! Front faceplate is in good condition.
Possibly to do:
- Adjust Bias... One side does run a bit warmer than the other. Measuring looks like it might be a bit tricky, so I'll do lots of homework before attempting. Advice appreciated if available. Will hold off, maybe buyer will prefer to do it.
- Replace transformer rubber mounting washers. I'm sure by now they have hardened some. Need to find a place that charges less than 80cents per piece!!! (hate home depot)
- no other ideas!
Still sounds great, if not better! Immediate clean audio from the relays! Have started to burn it this weekend. Very lush warm sound.
Still available! $450 or good offer, local Toronto pickup preferred! I'd keep it, but no space, and no need for a while. Original for-sale posting ad is somewhere in the marketplace section.
Old 30th April 2006, 02:24 AM   #2
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Pic's of Inside ? And Front ?
Old 30th April 2006, 02:28 AM   #3
Just getting to that....
Biggest time waster was trying to figure where to put the relay board, as the original crappy-plastic yammy binding posts suspended the board near the transformers. Found a good spot (reducing lead lengths, and still good airflow.
Thanks free mounting holes on the heatsinks, I could securely bridge the gap to suspend the board. (the 4 grey wires).
Picture 1... guts out!
Old 30th April 2006, 02:33 AM   #4
Part 2... guts out, another view...
Old 30th April 2006, 02:35 AM   #5
part 3...
relay up positioning, looks good but impossible to mount...
Old 30th April 2006, 02:38 AM   #6
part 4...
board mounted down, ugly but secure.
Old 30th April 2006, 02:42 AM   #7
part 5...
cover protector ON! Looks much better now....
Old 30th April 2006, 02:44 AM   #8
part 6...
Lookin' at the posts...
Old 30th April 2006, 02:46 AM   #9
part 7...
Put the cover back on... looks good seeing the transformers with the copper shielding, and without the crumbly rubber topsheet they used to have. Probably helped with sympathetic vibrations...
Old 30th April 2006, 02:54 AM   #10
part 8...
All done! Just a front shot...
Looks to easy, because you don't see any of the HELL of making a mounting plate for the posts... actually, wait for the next post...
I may toss in a shot of the gold plated relay at some later point. Never took any, but I'll keep the one I pulled as a backup.
There are actually 2 speaker out boards, the one you don't see in any shot was pulled out earlier. It's just square with no useful parts. The jumper Yamaha used for it is just a decent grade ribbon... yeek.
Just finished my first SI t-amp mods.. (no pics) nukegoat Class D 6 23rd October 2007 09:26 PM
Yamaha amp mods >HyperlogiK< Chip Amps 0 14th August 2007 03:16 PM
Finished Adcom 555 mods infinia Solid State 7 28th April 2006 10:58 PM
mods for Yamaha CDX-590 Mr. Triatic Digital Source 0 2nd March 2002 07:39 PM
Page generated in 0.13269 seconds (75.42% PHP - 24.58% MySQL) with 11 queries
