i'm designing a bass manager along the lines of the ICBM. Basic signal path will look like this: input -> buffer -> summing amp -> (buffer) -> output I'm wondering what opinions are regarding using a buffer such as BUF643, or using a regular opamp (I'm thinking AD843 for it's reputed bass performance) at unity gain for the buffers. Also, when used driving line-level signals, should i use a "hybrid" (ie buffer on output of opamp)? Does that fact that the summing amp will be inverted change that advice (specifically re the output of the circuit -- i can use the summing amp out put or put an extra buffer on it) thanks for help baald |
#2 | |
The hybred is not needed unless you drive really weird loads. An OPA134 driving an AD811 is a good choice for such a load problem. |
| output buffer for a hybrid amplifier | sparkle | Solid State | 121 | 8th July 2010 06:00 PM |
| Opamp Buffer | EchoWars | Solid State | 16 | 10th May 2007 03:49 AM |
| Opamp + buffer, how to bypass buffer at HF for unity gain? | Christer | Solid State | 10 | 29th October 2003 06:50 AM |
| opamp with/without buffer....??? | tbla | Solid State | 11 | 13th September 2003 03:18 PM |
| Page generated in 0.06676 seconds (68.31% PHP - 31.69% MySQL) with 10 queries |
