Singing Leach amp while burning in
Old 24th May 2006, 10:55 AM   #11
PMA is offline PMA  Europe
PMA's Avatar
Originally posted by Eva
Capacitors aren't.
You might be surprised. Try it, though I believe you have already tried.
Put a wound PP or PE capacitor as for stability test at amp speaker terminals and wobble sine tones at high output voltage level, or squares. I am sure that you will hear cap sing for some types.
Old 24th May 2006, 10:01 PM   #12
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
You're right, high value wound foil film capacitors may produce sound when subject to strong voltage swings or overvoltage, but that's not a condition likely to happen in a class AB amplifier. Note that I'm currently working into high power class D and using that kind of capacitors for output filters, but the inductors and even the heatsink insulators produce far more sound...
I use to feel like the small child in The Emperor's New Clothes tale
Old 25th May 2006, 02:42 AM   #13
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
funny, my dummy loads are in a tub of watter, only bubbles can be heard when the water starts to boil...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 25th May 2006, 06:20 AM   #14
PMA's Avatar
I know you are, and I appreciate yourk work in the field of switched power supplies and class D amplifiers.
Singing Leach amp while burning inHide this!Advertise here!
