Quad 405 hum problem
Old 17th May 2006, 04:32 PM   #11
try hard wiring the dirty returns together using the shortest insulated wire links possible.
Then run the shortest route to the central ground.
The short wires are to minimise inductance in the connections.
regards Andrew T.
Old 17th May 2006, 05:08 PM   #12
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
I think that resistors must be removed after regulators , as Andrewt suggested.
Also , zeners will open at something like 0,5mA or so (i am not sure).
You may try putting resistors to ground after zeners , so that they draw constantly a few mA of current and ensure that zeners are always open.
If the zeners would start opening/closing there mayl be some noise present...
Not sure about this , just some ideas ...
Lukas.
Old 17th May 2006, 06:52 PM   #13
vzs is offline vzs  Europe
I missunderstood what Andrew wrote in
Now that you have the supply working you may want to consider running a resistor Zener//cap AFTER the regulator
I drawed the resistor in the red sqare just to ask if that is what he suggested, but no, I do not have any resistor there.
In the quote he suggested to add an extra stabilizing stage using a dropping resistor (270r) and a Zenner (15V 500mW), but first if all I will try to hard wire the dirty returns toghether and run them to the central ground.
Zsolt
Old 22nd May 2006, 06:43 AM   #14
Thank you guys,
I was able to resolve the hum/noise problem .
The first noise problem was that I haven't connected the input sockets to the chassis directly at the point they were mounted.
And, indeed, the faint ssss noise in the speakers was due to bad grounding of the regulators and decoupling caps used by the input operational. Hard wiring them to the central ground removed the faint hiss too.
Zsolt
Old 22nd May 2006, 07:15 AM   #15
badgerboy is offline badgerboy  United Kingdom
badgerboy's Avatar
A friend of mine was trying to chase down a mechanical hum from an early 405. He tried mains cleaners, DC blockers on the AC-line, the lot. He figured out eventually it was the laminations in the mains transformer itself.
Listening closely, with the lid removed, he managed to strap his EAR across the 240vAC terminals on the top of the transformer!
I learnt new words that day...
Old 7th June 2006, 08:42 AM   #16
Hello all again!
I'm still upset with something and I couldn't find a solution for it:
Despite that there is no noise (hearable only if you stick your ears to the speakers) when the input is plugged to the CD player or grounded (volume to min), there is still a hearable noise (both 50-100Hz rail hum and noise) when the input is in the air. Also when I plug the audio cable to the input RCA (and the cable is not connected to the cd player) this hum+noise increases.
Although I know this is not a big problem it bugs me, so if you have some suggestions...
Zsolt
Old 7th June 2006, 09:26 AM   #17
it's good if there is no noise when the cables are connected and no signal is present.
Do you ever listen music on your system with the cables disconnected?
Have a look at the schematic. Is there a DC blocking cap on the input? Is there an input impedance setting resistor to ground from the amp side of that same cap to signal ground? Is there a DC referencing resistor on the other side of the cap (RCA end) to ground? If not then adding a high value 1M0 to 2M2 resistor from RCA input pin to RCA ground might help. But equally it might not, worth trying.
regards Andrew T.
Quad 405 hum problemHide this!Advertise here!
Quad FM4 problem JDeV Solid State 25 22nd December 2014 03:03 AM
Quad esl 63 problem howes hound Planars & Exotics 14 31st August 2009 05:40 PM
quad 606 mk1 problem kokheng Solid State 2 4th February 2009 01:26 AM
quad 44/405-2 another hum problem graeme uk Solid State 8 6th July 2007 06:49 AM
Quad ESL 63 problem. Please help DirkD Planars & Exotics 9 4th October 2005 02:03 PM
Copyright ©1999-2017 diyAudio
