Old 27th April 2006, 11:49 PM   #1
Default Question about weird diode arrangment
I have a question regarding the following schematic (for a Fender guitar amp):
http://www.st-andrews.ac.uk/~jcgl/Sc...oax/page6.html
If you look at the upper-left corner of the schematic you'll see two branches with three diodes in series. I was wondering what the purpose is of having these three diodes in series like that, and also why they have the markings on the diodes "-" then "+" instead of the other way around? With a typical diode, wouldn't you indicate the "+" on the anode (non-stripe) and "-" on the cathode (stripe)?
Me thinks that it's to drop the voltage, but the voltage is so high that I don't imagine that you'd get significant drop across the diodes.
Thanks for any input.
-Brian
Old 27th April 2006, 11:59 PM   #2
infinia is offline infinia  United States
infinia's Avatar
Hi
Your link is broken?
Didn't find amp schematic.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 28th April 2006, 12:34 AM   #3
doh! sorry about that. The link I originally posted was for another thread I was working on at the same time.
I could not find the original schematic I was referring to but I found the same arrangement in the following schematic (look at the bottom-center of the image):
http://www.guitar-parts.com/images/reverb6g15.JPG
Are they zeners?
-Brian
Old 28th April 2006, 01:02 AM   #4
infinia's Avatar
Series Si diodes to increase PIV (peak inverse voltage) of total string. Probably 1N400x 1 amp diodes. Does that make sense?
Old 28th April 2006, 02:05 AM   #5
Ahh yes that makes perfect sence. It didn't click in but yea it's pretty obvious now. Thanks bud!
Old 28th April 2006, 08:14 AM   #6
edl is offline edl  Hungary
edl's Avatar
As I see, the supply is 300V-DC, then in my opinion a lonely 1N4007 will do the job, instead of the three diodes.
Old 29th April 2006, 04:09 AM   #7
... and a better job, since the voltage across each diode may not be the same, and if you're a little unlucky one diode shorts followed very shortly by the others. Much better to use one diode, I believe that one can use resistors across the diodes to equalise the drops, still better to use one diode if possible.
Weird question about impedance revans Multi-Way 10 24th September 2008 08:52 PM
Sound levels - weird question! peter_m Everything Else 5 15th August 2007 03:36 PM
Diode Question TunaFish Tubes / Valves 8 13th October 2003 11:53 AM
Would this driver arrangment work? Hybrid fourdoor Multi-Way 6 10th July 2003 02:09 PM
Diode question Holger Barske Solid State 2 14th October 2002 02:44 PM
Page generated in 0.08772 seconds (78.04% PHP - 21.96% MySQL) with 10 queries
