strawa 50W
Hi there, found this one over the internet, called Strawa50W...
Comments please, suggestions... any kind of help is welcome...
This circuit will work. As shown, it will operate in class B so it will have crossover distortion thus sounding pretty bad.
You could take the 100 ohm resistor that is between the diode and the 3.3k resistor and change it to 390 ohms (based off simulation) or even put a potentiometer in there so you can adjust the bias.
Sith,
for most of us the powersupply, heatsinks, and the case of an amplifier are the parts that cost the most to construct an amplifier.
And that's without counting the time you put into it.
The parts and pcb's of the amplifier circuit is a relative small part of the total cost, putting time and money in a crappy circuit is a waste.
My reaction to the circuit you posted is: Yikes !
If you are thinking of constructing an opamp entrance amplifier, there have been so many designs since the mid 1980s, why bother with something so horrible.
Even an LM or TDA chipamp module will be easier and sound better.
Just love your dry sense of humor, DarkFenriz.
Hello, I saw this topic searching for something easy to build for unpretentious clients, so I don't lose my time in building good schematics for not so good listeners, so I decided to edit a little bit this easy circuit for some extra output power...
I would like it, if You people answer me some questions.
1. The 3k/2W resistors are calculated for 15mA current for the opamp is this enough ?
2.What output power will I get if I use my edited schematic on higher voltage than +/-45V with the MJ15003
3.What output power will I get with 2SC5200 on +/-35V and on +/-45V ? ? ?
I wait for your comments and recommodations...
This will not increase a single watt as the voltageswing is determined by the opamp... Don't use fast trasistors with that simple circuits, it might bite you with oscillations.
If you need it simple and powerful go for a bootstrapped topology, similar to the p3a...
Or see attachment... (have not build that) You can use the sc5200/sa1943 as output.
Mike
AKN
Joined 2005
Hi!
Can only agree with all negative posts on the first suggested amplifier and the "improved" variant . Will be very unlinear before feedback leaving lots of correction job to opamp.
There are so many much better amps as already suggested in this thread, and they will sound much better.
Anders
