My Hennessy preamp
My Hennessy preamp
Old 24th April 2006, 07:27 AM   #1
suzyj is offline suzyj  Australia
suzyj's Avatar
Default My Hennessy preamp
Hi guys,
Just thought I'd post up a couple of pics of my PGA2310 based preamp thus far - a shameless copy of Mark Hennessy's one (see http://www.mhennessy.f9.co.uk/preamp/index.htm but for stereo only, and with SMD parts.
It's able to select one of eight stereo inputs with relays, and uses a PGA2310 volume control, buffered with a OP2134 opamp. The control board is based on a PIC16F877A, with IR receiver, rotary encoder for volume control, and a graphical VFD.
At the moment I'm writing the firmware for the PIC, using Hi-Tech PICC-lite.
More design details can be found at http://www.atnf.csiro.au/people/sjackson/preamp/
Suzy
Old 24th April 2006, 06:02 PM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
My Hennessy preamp
Very nice work!
/U.
Old 25th April 2006, 12:59 AM   #3
anatech is offline anatech  Canada
anatech's Avatar
My Hennessy preamp
Hi Suzy,
I'm impressed. Very clean work indeed!
Let us know how it sounds when you are done. Good luck on your PhD!
-Chris
Old 25th April 2006, 01:39 AM   #4
Burnedfingers is offline Burnedfingers  United States
Very fine work. A work of art. I can't say enough good things about it. I know it will perform and sound great.
Old 25th April 2006, 04:05 AM   #5
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Nice looking PCB.
Old 10th May 2006, 03:00 AM   #6
suzyj's Avatar
Default Some progress
Hi guys,
I had a good night last night, and got much of the code working. I snapped a few photos of the control board doing what a control board does:
What can I say... The display looks really nice, and the Spectrol rotary encoder, even without a knob, is beautifully smooth and lovely to use.
More details are on the project's new home, at:
http://www.littlefishbicycles.com/preamp/
Suzy
Old 13th May 2006, 09:06 AM   #7
suzyj's Avatar
Default Source code
Hi all,
I've put up the source code as it stands so far on http://www.littlefishbicycles.com/preamp/. It's about three quarters done.
Stuff that works:
  • Power pushbutton
  • Display
  • Rotary encoder
  • source select pushbuttons
  • PGA2310 volume control
  • source select relays
There's a bug on the front panel board that has to be fixed to get the source select relays to work. The 74HC374 octal flip-flop that drives the relay driver has it's output enable connected to VCC . It should be grounded instead. D'oh!
There's still some work to do on the code. I need to add:
  • IR decoder routines
  • Clean stuff up.
In order to use the code, you'll need Hitech's free PIC C compiler, as well as MPLAB (all free). I used a PIC ICD2 cable to debug and program the micro.
Anyway, I hope people are finding this useful.
Suzy
Old 16th November 2009, 02:10 AM   #8
davi_C is offline davi_C  Canada
Hi Suzy,
I'am following your project and all i can say it's: WOW!! You've got talent. Actually i'am looking at your work and i wonder if you can post the schematic for this preamp. I only get the front panel and the main input on your website. I will appreciate because i don't have sufficient skill to design all that.
David
Old 28th December 2010, 04:42 PM   #9
jethari is offline jethari  India
Send a message via ICQ to jethari
Originally Posted by suzyj View Post
Hi all,
I've put up the source code as it stands so far on A HiFi Preamp. It's about three quarters done.
Stuff that works:
  • Power pushbutton
  • Display
  • Rotary encoder
  • Clean stuff up.
Suzy
Hi Suzy
Never knew you were on diyaudio. I bumped into your site a while back and was mighty impressed with your preamp. In fact, now its my turn to shamelessly copy your design. I've made a few changes though, instead of using the dB values, I'm using a bargraph for volume, bass, treble and balance(i've added the tone and balance controls as well). Where I'm stuck now is the IR routines. I'm desperately looking for some usable IR routines in C. I'm no good at modifying asm files. I wonder if you have made any progress with your IR routines. Please do let me know.
Hari
Old 28th December 2010, 11:31 PM   #10
currentflow is offline currentflow  United Kingdom
Hi jethari,
You might be able to modify the code in this link for your needs:
mikroElektronika View topic - Philips IR RC5 protocol
Note: TIMER0 prescaler needs to be set to 16 for a 4MHz crystal.
currentflow
My Hennessy preampHide this!Advertise here!
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 05:52 AM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Instruments and Amps 1 12th March 2008 06:16 PM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 10:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 08:32 AM
wiring preamp outs on a preamp bonsai171 Solid State 4 22nd March 2004 11:13 PM
Copyright ©1999-2017 diyAudio
