I popped out a fuse near the transformer on my C-2 for inspection and it came apart, so I need to replace. The fuse is AGC type 1/4 x 1-1/14 size, there is a 250V rating on it, but no amp. What are these when they do not indicate an amperage? BTW, the filament is about the thickness of a lightbulb's...
#2 |
Hi DreadPirate,
What does it say on the rear panel by the fuse holder? It's probably a slow blow type given the low current rating. You can use a 1/4 to 1/2 amp just to test. Do not fail to install the proper type. The only reason I give you this advice is that we know the preamp is not drawing excessive current. -Chris |
#3 |
You can always connect a DMM across the fuse clips if you can access
them and check the current. GOOD LUCK |
#4 |
Hi willyhoho,
That will give you an error. With preamps and other low current devices, the turn on surge is far, far greater than their steady state current draw. The fuse is sized larger than you would expect and is also generally a time delay type. Otherwise the warranty program would kill them! The fuse rating ought to be marked on the chassis near the holder, or just inside the chassis near the holder. No guessing required. -Chris |
#5 |
The fuse has only "250V" on one end and on the other end "BUSS AGC1/4". I ran out and got a .25A fuse and all is well. There wasn't anything written in the vicinity of the fuse.
#6 |
Hi DreadPirate,
Then do yourself a favour and write the fuse value inside the chassis near the fuse holder. If the new fuse blows randomly, replace it with a time delay fuse. -Chris |
| Power Supply Rating / Fuse calculation / Understanding ? | artquake | Power Supplies | 23 | 24th June 2008 09:41 AM |
| amp rating for fuse and fuse holder? | riotubes | Parts | 5 | 27th August 2006 03:10 AM |
| Mystery Fuse | honsten | Solid State | 1 | 25th July 2004 08:05 PM |
| Help - fuse rating (USA style) | TNT | Parts | 2 | 7th March 2004 03:04 PM |
| Fuse Rating | jwatts | Multi-Way | 3 | 6th January 2004 08:37 PM |
