Hello everybody
I'm trying to build a +/- 15V regulator using TL431 but I feel kind of clueless about the negative regulator. The regulator will be driving a JLH headphone amp(circuit 2 at http://www.tcaas.btinternet.co.uk/jlhphones.htm ) My idea is something like this for the positive supply and something like this for the negative supply I only have a trafo that will give +-34V regulated at the moment if your wondering about the high supply voltage. I'm biasing the tl431 with about 10mA since that should be adequate. Any thoughts? Thank you for reading this /Lovan |
#2 |
Electrons are yellow and more is better!
It might work. One way to find out is to simulate it. You could use the freeware SwitcherCAD (LTSpice) from www.linear.com
/Per-Anders (my first name) or P-A as my friends call me |
#3 |
The Vbe of the output transistor will be effectively substracted from the 2.5V reference so that negative arrangement is not practical.
You may connect the 5K resistor to the base instead of the emitter and use the TL431 as a plain zener, though. Otherwise, consider a LM337 1.5A negative regulator.
I use to feel like the small child in The Emperor's New Clothes tale |
#4 |
PA: I have never understood how Spice works but I will try it out sometime.
Eva: Thank you for your reply. If I use a tl431 as a zener how will it compare to a regular zener? better or worse? Maybe I will just start with zenerregulators for both positive and negative. I thought that a passregulator would be better than a lm337/317 since I will draw almost constant current? |
#5 |
Eva, you are right here.
You might take a peek at Sonny Andersen's current feedback amp. He uses LM431 for negative voltages. www.mirand.dk
#6 |
If I remember properly, TL431 is substantially noisier than any zener above 10V (low voltage zeners are noisier too). However, output impedance is much lower for the TL431 thus yielding much better line and load regulation. Also, TL431 has very good frequency response despite its active nature, producing a low impedance ouput up to at least 100Khz.
If your input voltage does not sag too much and your load current is low, you may consider the TL431 as a plain shunt regulator in each rail (see the datashet if you don't understand). That's a simple yet effective solution. Consider also the LM317/LM337 pair. These regulators are widely available and perform quite well for their low cost.
#7 | |
Many people here know how to use this particular software so why don't you start to simulate.
#8 |
PA: I had a quick look at his schematic. It's interesting. I will have to think about how it works for a moment. I'm quite slow I know
Eva: Thank you again. I think that I will try tl431 as zeners to begin with. I thought about the shunt but I think I would need to use it with a transistor becuase of the current needed. I will try the LM pairs too. Thank you very much for your inputs. |
#9 | |
#10 | |
All push pull ClassA topologies are not constant current.
regards Andrew T. |
| What's really going on in that TL431 | jackinnj | Power Supplies | 3 | 6th May 2007 01:22 AM |
| to mach1: tubecad regulator using tl431 | jarthel | Tubes / Valves | 10 | 16th November 2006 01:03 AM |
| help understand the TL431 | jarthel | Parts | 6 | 1st October 2006 09:09 AM |
| TL431 Question | vectorplane | Power Supplies | 2 | 5th March 2006 10:47 AM |
| Tl431 | sparkle | Digital Source | 11 | 22nd February 2004 09:10 PM |
| Page generated in 0.12846 seconds (77.08% PHP - 22.92% MySQL) with 11 queries |
