I just found out about these!
has anyone tried them out? ive ordered some samples, im not sure that they have a spectacular noise figure or anything, but they look very useable.. Are there any competition I.C's to these around? Would an 8th order sullen-key filter be better? http://www.maxim-ic.com/quick_view2.cfm/qv_pk/1370 |
#2 |
As you increase the order of an analog filter the tolerances of the components required get tighter and tighter, that is, with a 12dB/8vo filter you can probably get away with 1%, with 24dB/8vo it's more like 0.1%. OTOH, there are other problems to consider with switched cap filters:
With switched cap filters you have to post-filter to remove the clocking noise. Maxim doesn't state this in their PDF. Note the noise figure and distortion -- -70dB -- well at least you will be able to measure it. |
#3 |
diyAudio Retiree
For what?
high distortion high noise Extremly! low power supply rejection. These filter types are maginal for all but the lowest fidelity uses. I have even had trouble with them in voice frequency low end telcom applications. Not even worth trying, Fred Its Sallen-Key, not sullen-key, by the way. Sullen is what you will be after reading this post. http://www.bartleby.com/61/68/S0876800.html Sallen-Key http://www.altavista.com/web/results...ls=1&avkw=qtrp |
#4 |
on Sallen-Key filters. It is well worth downloading.
#5 |
So i forgot how it was spelt... Sullen im not.
#6 |
Ive been checking out other manufacturers, seems LT make an ultralow noise model.. Ive got samples on the way, thanks for the input!
| DIY Low Pass and Mid/High Pass (Bass Blocking) Filters | runslikealpaca | Everything Else | 1 | 19th June 2009 11:59 PM |
| Need formulas for multi-poles RC low pass passive filters | gaetan8888 | Digital Source | 9 | 13th March 2008 04:59 AM |
| A question on low pass filters | Vaughan | Subwoofers | 15 | 10th October 2007 05:23 AM |
| Maxim AN1931: USB-Powered High Precision Phono Preamp | lineup | Analogue Source | 0 | 17th December 2006 09:52 AM |
| High-Pass Filters? | pixie | Multi-Way | 4 | 17th September 2006 04:02 PM |
| Page generated in 0.07629 seconds (78.26% PHP - 21.74% MySQL) with 10 queries |
