Old 20th November 2002, 10:02 AM   #1
edm is offline edm  Netherlands
Default Volume control
I'm in the process of designing a remote controlled preamp and after some extensive searching on this great forum i found one proposed by Maik Herzog.
For more info see:
http://mitglied.lycos.de/MaikHerzog/...eamp_text.html
I thought this was an interesting idea. I would like to control the volume control with a microcontroller. To make this volume control disaster proof (i am going to write the code for the microcontroller myself ) I thought it would be a wise idea to have one of the voltage dividers 'switched on' and therefor I toyed a little bit with spice and created the thing in the attachement.
The blue section is what is originally proposed by Maik Herzog, the red section is what I added and the yellow section is the 'switching voltage'. In spice it seems to work. Since i am an electronic noob, i would like to ask can this be done any simpler / better/ etc.
Emiel
Old 20th November 2002, 11:33 AM   #2
SDF is offline SDF
Hi !
I made a passive remote control preamp based on an ALPS motorized potentiometer and controlled by ATMEL µcontroller. If you want follow on this way....don't hesitate for any information.
Old 20th November 2002, 11:40 AM   #3
I want to use this volume control in a 6 way preamp, so i thought this would be the most convenient route to go. I have considered alps potmeters, pga2310, ds1802 btw, but wanted to try this approach in a stereo test setup.
Old 20th November 2002, 12:21 PM   #4
SDF is offline SDF
You should go search 6-way volume peamp, there is a good thread on solid state amplifier forum. With some good links.
Old 20th November 2002, 12:41 PM   #5
You mean this topic:
6-way volume control
I have done some extensive searching for some time now on this topic, to me the approach of Maik Herzog seems worth a try. The only thing i would like to have is that one switches is default on instead of off (this sounds confusing). The reason is simple in case of malfunction of my microcontroller or something else, i don't want to fly through the roof because the volume is wide open .
If this approach doesn't work out, i will look for something else. Perhaps the famous Wayne attenuator (hope i spelled it right) is out in the open then?
I hope this doesnot sound inpolite, i am simply looking for improvements/remarks on the schematic i posted. I know about the various other options out there, but thanks for your help anyway.
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 08:20 PM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 04:12 AM
The remote control paratactic volume control audio-gd Solid State 33 8th June 2007 12:16 AM
PC volume control sumacSK Chip Amps 9 28th November 2005 06:33 AM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 12:12 PM
Page generated in 0.08737 seconds (68.80% PHP - 31.20% MySQL) with 11 queries
