#601 | |
Looks like Sponge Bob has killed another thread. |
#602 |
Yep, thats what I measured on the working channel, the negative side Q-7, Q-8 measures the same. The non working channel measures about the same on those devices. There is not any real difference till I measure the collectors of Q-9 and 10... those are a volt lower than the good board.
Those readiings taken are in this order...... Drain Gate Source Mark |
#603 |
Official Court Jester
do you have same readings on R24,25,26 and R27 on good and bad board?
around 1V5? also -same case with R22,23,28 and R29 ? each predriver (mosfet) must have 1mA5 through......
my Papa is smarter than your Nelson ! tnx to |
#604 | |
I will get back in an hour or so on the reading across those resistors. Thanks Mark |
#605 |
If that doesn't work, get the scope out and try tracing the signal, see how far it gets.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#606 |
Actually the board drives my YAmaha NS-10 just fine so signal is flowing as normal... I had looked with a scope and it all seems fine. The problem is with that low voltage in both Q-9 and 10. It may be related to something behind it though... The OP stage doesn't even get warm!
#607 |
Dodgy bias pot?
#608 |
It checks good... I measured all the resistors in the circuit... all good.
#609 |
Hmm. Other than a soldering error, I can't think of anything else offhand. It's past midnight here, so I'll sleep on it and see what I can think of in the morning, assuming of course you haven't got it fixed by then.
#610 | |
replace everything (or one by one part) after mosfets,IF voltages on mentioned resistors are OK...... bad resistor ,or transistor or pot; start with pot
| Page generated in 0.12017 seconds (76.34% PHP - 23.66% MySQL) with 11 queries |
