#51 |
Sweet is sugar, honey, wine... What is sweet sound ? Is here technical forum or club of cooks ?
#52 |
i think we should stick as close to the original desing as possible, including using devices that are as close to the original as are avalalble, otherwise this would not be a Krell clone.
are you sure? |
#53 |
Some things might be easy, others more complicated. What are the pinouts of the JFets and ZTX. Do the JFets need extra support components, or will they drop straight in?
You guys need to come up with answers, not more questions!
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#54 | |
#55 |
Me too, Al...I was cooking at AM...
#56 | |
Flodstroem, Andrew, Take a look at Mr Macleans site and look at the actual KSA-80 manuals and also at JWB's thread. I believe that the KSA-80 used a similar supply. Take a look at JWB's thread and schematic starting in Post 12 of the KSA-80 regulated supply. It is probably very similar to the KMA-100's. Note that the power supply WAS part of the KSA-80 main board and its a relatively simple supply. Andrew...... Unfortunately I let go of the KSA-80B about 6 years ago. I wish I had kept the thing. The manual states that the rails in the KSA-80 were +/= 75 volts and the bias was 325mv across the 1 ohm emitter resistors. On all versions of the KSA-100 the bias was set for 575mv across those 1 ohmers. Hopefully this will help you out...... Al, The fries are getting overdone JWB did not thermally couple his together in his KMA-160 rebuild, they are quite small in size so it is probably not really necessary since they will change temp from the ambient quite rapidly. Other than these parts I think you are already familiar with everything else used. Mark
KSA-100 WIKI |
#57 |
Here is a link to data on the old Supertex MOSFETS that were used but are now obsolete. Krell used the TO-220 versions of these devices.
VP0210N5 VNO210N5 Mark
KSA-100 WIKI |
#58 |
It's tempting to adapt the input stage of the KMA, just so we have a balanced option.
#59 |
Mark I agree totally.
are you sure? |
#60 | ||
pinkmouse:
Regards Flodstroem |
| Page generated in 0.14129 seconds (74.12% PHP - 25.88% MySQL) with 11 queries |
