#531 |
Heres my KSA 100 board
#532 |
Well, it gets a teenie weenie bigger if you click on it.... I hope the sound is larger than the picture....
.Mark |
#533 |
Hows this
#534 |
Is that a MK-1 or a MK-2 board... Looks like a MK-1 to me. What devices did you use?
PWatts, Can you measure the length of the KSA-100 heat sink tunnel for me? I have a 4 foot section of the stuff that I'm planning on using to build my pair. Thanks! Mark |
#535 |
Kudos to Lee1234 to building a Mk1 on such a small single-sides board. Layout's not completely optimal due to that marge MKP caps, but it would make a nice little headphone/tweeter amp. Hope the bias and offset remain stable with the bias transistor separate from the driver/output heatsink.
Mark, I'm continued to be amazed at your speed! Told you the Mk2 sounded good.. personally I wasn't too keen on the Mk1 (in my own system anyway, where I preferred a Rotel). If I remember correctly Alex said here that Krell Germany has found bias ifor the Mk2 in the region of 380mA to be the optimal point sonic-wise. Perhaps that needs to be investigated so potentially save many builders unnecessary large transformers, caps and heatsinks. The Mk1 I serviced's bias was also reduced from 100W to 80W with no change to the sound, but a noticeable reduction in heatsink temperature and ripple. The heat tunnels are exactly 100mm high. Must have been made in Europe since all the screws etc. are imperial sizes - a b*tch if you don't have complete sets of imperial sockets, wrenches and allen keys |
#536 |
Well, having that old Cerwin Vega amp really helped me get things done alot faster. The second board is also assembled as well but I have to machine the second sink. Next weekend I should have both channes playing. ONe thing about the 100 that thr 50 is lacking is the ability to shake things in other rooms of my house....amazing LF control and response that just is not there in the 50
Mark |
#537 |
Gentlemen
It so nice to see the Krell magic I grew up with beginning to kick in again. It going to be really interesting to see how big this wave is going to get? With a better board layout- top notch components and better wires I would not be surprised if the new boards outperform the originals. I wonder how many KSA50 clones will soon be running with the new KSA100 mk2 boards? Jozua
#538 |
I will change the power capacitors in the KSA 100 MK 2. The Sprague Powerlytic 36DE on the KSA 100 is unavailable ! Itīs of 1987. Sprague Powerlytic 36DE 40000 - 90DC 8747L 4301 Made in USA + 95 C Whatīs extra or difference to other capacitors ? Is the Sprague very good ? What can I to use for a good capacitors ? Best regards Alex |
#539 |
Try the new ones from Sprague or BC Components at Vishay. You can get 47000uF at the same diameter but a few cm shorter than the originals.
#540 |
Hi
Does anybody know who supplies Krell with their capacitors ? Jozua |
| Page generated in 0.12538 seconds (72.05% PHP - 27.95% MySQL) with 11 queries |
