#41 | |
or very big cheese graters "family size" or morgue table allan
Indecision makes the world gone round. Maybe |
#42 | |
Mark:
Im in for 6 boards of the KSA100 MK-2. Regards
Regards Flodstroem |
#43 |
It seems the logical way to go to me Flodstroem. The Mk-2 board is certainly able to please all others merely by jumpering out components and changing other parts values.
Mark
KSA-100 WIKI |
#44 |
Andrew, if exist something like recomendation about impedance of speaker and somebody wittingly ignore it, how do you can term it ?
Mark : Some more, some less....Krell markedly...
#45 |
Here are a couple of photos of the inside of the KMA-100. It appears that the power supply regulator and the main board aare stacked together on one side and the power supply also looks a tad larger.
Mark
KSA-100 WIKI |
#46 |
Another vuew of the power supply regulator board and main caps.
KSA-100 WIKI |
#47 |
Hi Mark
Any idea for what reason Krell used a power supply regulator ? Was its purpose to rise the efficiency of the output stage (this could be done by having a 5-10V higher rails on the input/driver stage) Or was the purpose to lowering power supply ripple noise/buzzing? Maybe both. A long time ago I built a Pass 40W Class-A and implemented a solution similar like the Krells (I think but Im not sure about that). I think I used a regulator for ± 7-8 volt higher/lower than for the power devices who was darlingtons). The benefit for doing it for me was lowering power supply noise AND a rise in power output capability, thus rising the efficiency of the amp (also: rising the total audio quality ) Wandering if this implementation should be located together on the amps driver board ? It could be done though its not a high power circuit. Or is it impractical? (benefit: you only need to make one board, not two. drawback: a more complex board/circuit) What do you think? Regards
#48 | |
I am using the j176 jfet and do not know its complimentary version, but there are a whole range of mA versions for more or less driver power. It seems to be more spacious and much more extended in the highs with less distortion. I have compared the j176 to the zvp3310a and found the zvp3310a is still very nice sounding, but not quite as sweet. Since, we are designing a new board, I think this would be a good time to check on jfets. They do make a great big improvement on my Aleph 3. Mark, when your ready, I could bring my Aleph 3 over to let you compare the zvp3310a in your mini Aleph vs the j176 in my Aleph 3, so you can decide what you like. Regards, Bill |
#49 |
I am in for 4 set MKII
Thanks |
#50 |
Hi Mark,
do you still have that KMA? to take measurements and read off the psu data (+-80mF?)
regards Andrew T. |
| Page generated in 0.60169 seconds (19.94% PHP - 80.06% MySQL) with 11 queries |
