Krell KSA 100mkII Clone
Old 29th January 2010, 10:01 AM   #2431
R.I.P.
yes +-42Vdc is OK.
You must change some resistor values and maybe the Zener values.
The currents in each of the devices must remain the same as when driven by +-52Vdc.
regards Andrew T.
Old 29th January 2010, 10:44 AM   #2432
samoloko is offline samoloko  Bulgaria
thank you Andrew
great to hear It from expert
resistor values to change are 1 Ohm emitter resistors In output, right
what Is min voltage of rails needed In order not to change the zeners
would you please tell what are your amp specs
I still don't know what toroid to buy - I don't need 100 W at 8 Ohm and so much heat but want to be close to original amp
last question how this amp compares to Nelson Pass amps
I have build F5
Old 29th January 2010, 11:17 AM   #2433
R.I.P.
I am no expert.
I think I am good at sorting the wheat from the chaff, but I get that wrong as well.
regards Andrew T.
Old 29th January 2010, 06:41 PM   #2434
Andrew
what about second part of my post
Old 29th January 2010, 07:59 PM   #2435
a.wayne is offline a.wayne  United States
Sin Bin
^^ uhhh ,huh ...............................
Old 3rd February 2010, 02:37 AM   #2436
wilsonaudio is offline wilsonaudio  United States
hello anyboddy has schematics for power supply on projet krell ksa 100
Old 3rd February 2010, 04:22 AM   #2437
neychi is offline neychi  Croatia
Here it is
Old 4th February 2010, 12:35 AM   #2438
thanks neychi
Old 4th February 2010, 09:06 AM   #2439
except Fix how many DIYers build that amp
Old 4th February 2010, 09:37 AM   #2440
R.I.P.
Andrew T did. But, could not achieve good sound and stability at the same time.
reports July & August 2007.
regards Andrew T.
Krell KSA 100mkII CloneHide this!Advertise here!
