#2421 |
And (sorry for asking) the Class A max power cannot exceed the Class AB power, ever...correct?
Class AB power is the upper limit?
Pillage Before You Burn. |
#2422 |
I guess you could keep biasing up till the Class-A output matches what the rail's limits are, at the point, class A ouput should = AB... theoretically speaking ...
#2423 |
tell us what voltage you want across your 1r0 or 1ohm (reactive) load and we will show you why you should not try to achieve ClassA into a 1ohm load.
regards Andrew T. |
#2424 | |
Increase the output stage to 12pairs of MJ15003/4. Increase the bias current to 6A (500mA through each). The total dissipation is now ~51V * 6A * 2 ~600W The maximum ClassA output current is ~12Apk The maximum output voltage is ~45Vpk. The peak transient current into a an 8r0 resistor ~45/8 ~5.6Apk. This is well inside the ClassA limit. The peak transient current into an 8ohm speaker is ~45/8*3 ~16A. This is outside the ClassA limit. If we biassed a 100Klone to about 16A, total dissipation ~1.6kW, it should just about never leave ClassA driving a real 4ohm speaker load. Biassing a KSA100Klone to 6A can never guarantee that it does not enter ClassAB with a real 8ohm speaker. Similarly, we hit a current limit long before we hit a voltage limit with low impedance loads, eg. 4ohm and 2ohm.
regards Andrew T. Last edited by AndrewT; 10th November 2009 at 01:40 PM. |
#2425 |
hi.I have 600 VA torodidal transformer and it has 4x18 volts output.I will connect in series and have 2x36volts ac.I am planning to build a low bias Class AB krell ksa100 or ksa50 version amp with this transformer..How many output transistor should i use? I have MJL1302/3281 and NJW132/3281 transistors.and which of them are more suitable?thank you
#2426 | |
Yes, i have done the calculations and 1 ohm class A operation is not feasible . I would assume a sliding bias would be the best route , class A for the first 100 watt @ 8 ohm which would net 12.5 watt@ 1 ohm or 25 @ 2 ohm on the revised speaker imp of 1.8 Ohm ... Now to select the topology to use , any suggestions there ? |
#2427 |
hey there ? I remembered there were class aab krell ksa 100 amps on krell viki. no answers ?
#2428 |
I am in the process of building a KSA50 Clone. On the boards I obtained and the circuit diagram the value for C105 and C106 is 22pf, yet on other diagrams I have seen the value is 390pf.
What is the correct value? Quote:
#2429 | |
#2430 |
Hi
I got a question regarding lowering original rails +/-52Vdc - I don't want so much heat what Is min rails value which I can use with Krell KSA100 mk2 clone pcbs I will use original bias setting - Ure - 625 mV I don't want to modify pcb are rails at +/- 42 Vdc good enough |
| Page generated in 0.14774 seconds (72.09% PHP - 27.91% MySQL) with 11 queries |
