Old 4th November 2009, 02:02 AM   #2411
RKH is online now RKH  United States
Beautiful work. Great test results. Congratulations. I recognize those transformers I trust they are doing the job?
Ryan
Lighten up while you still can ...
Old 4th November 2009, 02:10 AM   #2412
WOW! Thats an amazing high quality build!!! Can you send me an 11X14 color glossy enlargement to hang on my wall??
Mark
Old 4th November 2009, 02:23 AM   #2413
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Fit ,
Congrats and fantastic job , what was the power output @ 2 /1 ohm respectively ...
regards,
Old 5th November 2009, 06:39 PM   #2414
Fix is offline Fix  Sweden
@ a.wayne..
Press on the pictures to zoom in, then you can see all outputs...
I have an official PowerCube reading for KSA-80B, will post results tomorrow.
KSA80, have similar effect in 8,4,2 Ohm, and KSA-100 have quite much more power in 1ohm
Old 5th November 2009, 06:44 PM   #2415
a.wayne's Avatar
Hello Fix ,
Yes i did zoom in later and saw the output figures , Impressive ! again great work ..
Old 9th November 2009, 12:30 PM   #2416
Here are the KSA-80B Audiograph results.
Done by Swedish magasine Hifi & Musik, 1996
Same as did test mine...
We can see that the KSA-80 have more power in 8,4,2ohm and drops at 1ohm
KSA-100 have more power at 1ohm, and is more stable.
Also if we raise the bias to 625mv, I guess we get more power too..
KRELL KSA 80B
8Ohm
158W 60deg Cap
157W 30deg Cap
156W 0 deg
157W 30deg Ind
159W 60deg Ind
4Ohm
303W 60deg Cap
294W 30deg Cap
292W 0 deg
296W 30deg Ind
302W 60deg Ind
2Ohm
557W 60deg Cap
518W 30deg Cap
506W 0 deg
518W 30deg Ind
545W 60deg Ind
1Ohm
403W 60deg Cap
407W 30deg Cap
421W 0 deg
417W 30deg Ind
332W 60deg Ind
MCC POS: 70A
MCC NEG: 0A*
*could not measure ?
Old 9th November 2009, 07:35 PM   #2417
no,
you get more bias current which in turn means you have more ClassA output current.
regards Andrew T.
Old 9th November 2009, 07:42 PM   #2418
john65b is offline john65b  United States
john65b's Avatar
And all this power beyond the Class A max is all Class AB, correct??
Pillage Before You Burn.
Old 9th November 2009, 08:27 PM   #2419
yes ClassAB as soon as the peak current exceeds the ClassA output current.
For 2.6A bias the maximum ClassA current is ~5.1A and is good for 100W into 8r0 or 50W into 4r0 or 25W into 2r0.
regards Andrew T.
Old 10th November 2009, 03:05 AM   #2420
a.wayne's Avatar
How would one achieve class -A bias into 1 ohm ?
Page generated in 0.11753 seconds (73.78% PHP - 26.22% MySQL) with 11 queries
