#221 | |
I have thought it out and I agree that this board should stay one piece and that it also needs to be a drop in replacement for the KSA-Mk-1 version... screw holes and size from the original KSA board are paramount to take into the new board design. Since I will be supplying the heatsink with the boards this shouldn't even be an issue... and the heatsink we will be using has much more dissipation area than the original one Krell used. Also If I make the run of boards they will be 2 oz copper same as the KSA-50 boards were... and gold plated for sure. This will aid in pads not comming loose from too much heat and it will also serve to sink the heat better for the Zetex devices. The boards also need to be a close color to the original Krell board so owners of the amps can do a board change with very little astetic change. Linesource, This board has to accomodate everyone within reason. Some may use flat back sinks and I for one will be using the exact same air tunnel that Krell used since I have 2-four foot sections of it. Others might use the big square heatsinks such as were used in the KSA-80. All in all a one piece board is not practical. What might be practical would be to make several seperate output boards for several different devices. I use TO-3's but many others use the TO-247 package. Your input on designing seperate output boards might be helpful though. I agree on making it a monoblock.... its way too heavy otherwise. I have a 2 kva tranny just in my KSA-50! Mark
KSA-100 WIKI |
#222 | |
PWatts: If its any help I can send/e-mail you this footprint so you can check this out (but Im not sure about the file-format I and you use in the CAD softwares). Regards
Regards Flodstroem |
#223 |
I agree with Floedstroem on the heatsinks 100%!
Mark
KSA-100 WIKI |
#224 | |
PWatts:
#225 | |
After owning KSA100 and KMA100s I would never own another amplifier with a fan. NEVER! I could alway hear the Krell fans, the fan sucked in a lot of dust that required frequent cleaning, and all of the fans broke after a few years. None of Krell's current products use a fan - for good reasons. I cannot think of a top ranked amp that uses a fan. A high power Class-A amp that relies on natural convection air cooling needs 2.5"-3" deep fins, separated by 0.1"-0.2", lifted about 1"-2" off the floor to create a thermal pump to flow enough air mass to transfer and conduct the heat. I would ask all builders to re-consider the single PCB design using natural convection air heatsinks like the KL-271 profile. One team engineered complete reference design would give high novice success and still allow experts to make modifications. It sounds like very few builders plan to use this PCB to replace old Krell PCBs, as these should be repairable. |
#226 |
Linesource,
There already exists a board you can get from China if anyone wants to build it that way. So why waste time designing one when one already exists. The KSA-50 board as it was done by Pinkmouse with input from the group has worked out extremely well and all that have been built so far have been VERY sucessful. I'm not a big fan of plastic power devices and thats my main reason for using the original tunnel design sink. And ok, I got the 4 foot sections as surplus very cheap. Flat back sinks are very expensive to buy new and are not easily adaptable to the TO-3 without another adaptor to connect the TO-3 to the sink.... adding another thermal resistive joint and decreasing transfer efficiency. Although I will P to P wire my O.P. stage I can see merely taking the Pinkmouse output board and expanding the number of devices on them to the number agreed on. Then making them available with this board or as two snap off boards connected to the main board. The latter was done for the KSA50. This still makes wiring the OP stage a snap and with a very minimum of short run hard wiring involved.... The main thing is that going this route keeps things much more flexible and the group order will be larger and boards will cost less. IMHO Krell did very little in regard to fan type or optimum operating speed/vs. Noise level. I won't argue on fan reliability though... its always a problem. Because I carefully selected my fans I can't hear them on my KSA-50. I coulda made yours virtually silent and with an fan life of about 5 years if it were left on continously. The end result of this project has to be aimed at the many, not just the few. The sinks you mention are not easily or economically available in all the countries this amp might be built in. This project has just really gotten underway and the addition of output boards is cetainly very doable. I don't think you will find many novices building this amp irregardless of how the board is done since the cost is going to be quite high because of power supply and heat sink requirements. As for owners upgrading their amps that is totally unpredictable but making a board that will retrofit in at this point in time is a cinch with the present design. This covers yet another possibility. I for one would certainly be willing to make assembled and tested boards available to owners and service shops to do the upgrade. In fact the Pinkmouse KSA-50 board would easily retrofit into an old KSA-50 if the driver board were left attached to the main board. Mark
KSA-100 WIKI |
#227 |
Attached image of "a" China KSA 100 PCB.
I owned both KSA100 and KMA 100, and the KMA100 was significantly superior, stronger bass, sweeter high frequency ...not sure why ...could be regulated power supply for front end driver stages ....which would also fit on single large PCB. Anyone else own both and can comment? |
#228 |
From Krell Website....major product introductions
1980 Dan and Rondi founded Krell in order to bring new amplifier designs to market unfettered by the understandings of other engineers and executives about product viability and design. Krell introduces its first product, the KSA-100, which is the first high-power, high-current, true Class A biased stereo power amplifier to enter the market. The young company struggles to meet unexpectedly high demand as the KSA-100 is embraced by audiophiles of the time. 1982 Krell introduces the KSA-50, a smaller and less-costly version of the KSA-100. Again demand soars beyond Krell’s ability to supply. 1983 KMA-100 and KMA-200 mono amplifiers introduce DC coupling from input to output, eliminating capacitors from the signal path. They also contain fully regulated power supplies for the front-end voltage gain stages and sophisticated protection circuitry for the output amplifiers. These innovations, coupled with massive power supplies, enable Krell amplifiers to drive any speakers with ease. 1987 The KRS-200 mono power amplifier brings convection cooling to Krell products, eliminating the previous fan cooling. It doubles the standard for Class A power and quickly becomes the reference standard for modern amplifier design. It also sets the world standard for substance, 5.6 cubic feet and 240lbs! 1988 With the KSA-80 and KSA-200 amplifiers, Krell introduced fully balanced amplifier design, which maintains balanced operation from input to output. 1989 Krell pioneers the use of 64X oversampling in digital circuitry in the SBP 64X digital to analog converter. |
#229 |
Far as I know the KMA-100 regulated supplies were similar as was done for the KSA-80. That power supply schematic is on page 5 of this document in the lower left corner
Mark
KSA-100 WIKI |
#230 |
It's great to hear people are agreeing with the idea of making it a drop-in replacement for existing KSA's - I know somebody who owns both a MK1 and a MK2 and I'm sure he'd like the oppportunity to upgrade the Mk1 without risk of damaging the boards. Same goes to boost the Mk2 with better quality components without having to rape the old boards.
Regarding the position of the predrivers: They cannot go higher or lower, i.e. vertical axis is fixed. Lower and it goes into the already occupied space, and higher it will limit the area for the driver heatsink even more. I can shift the outer ones a bit more to the sides though, but it will lengthen the signal path.. guess I'm overly cautious since I'm still in the mindset of doing gigabit digital designs One has to keep in mind that the inner two predrivers will dissipate less than 100mW each and is likely to be fine with a small clip-on heatsink or even no heatsink at all. The outer ones are about 1W each. I thought more in the line of a single piece of angle iron for the lot instead of separate heatsinks, one per pair. That looks so much better than the four singles in the original which IMO looks quite dodgy. But if the voice of the masses says same sinks, so be it. Flodstroem, please email me the footprint, I'll msg you my address. 145mm wide board is no problem (I think the original is 150mm), but to space the predrivers so far apart is going to mess with the design. Isn't it possible to use narrower sinks or something? Or smaller ones for the lower-power ones? Has anybody ever felt how warm these things get on the original? I know the drivers get way too hot to my liking but cannot remember the predrivers. Alex, if you see this, would you please do the effort of drawing up an exact picture/description of the original board wrt dimensons and positions of the wire pads and mounting holes? Linesource: The first time I read the part of Krell introducing the SBP I thought for a while it stood for Sound Blaster Pro |
| Page generated in 0.17379 seconds (81.89% PHP - 18.11% MySQL) with 11 queries |
