#1911 |
Hi Jacco,
that Aragon circuit you mention above certainly looks similar to the KSA50 amp. PWatts' description of the original KSA50MkII is also similar to that circuit. Is the Aragon amp newer than the KSA100MkII and the KSA50MkII amps? Hi Jozua, when you have time can you please measure the voltage across the zener diode in the original KSA50MkII - but don't short anything out. Thanks |
#1912 |
Mondial was founded in 1986, Mr d'Agostino designed the MKI Aragon power amps in 1987, both models were introduced overhere in '88.
The later MKII 2004/4004 were designed by Mr Kusiak, who joined Mondial in 1990.
Looks like Sponge Bob has killed another thread. |
#1913 |
Got these from the eBay seller in Hong Kong. Suspicious of the origin...
#1914 |
Other side...
#1915 |
These I know are real...
#1916 |
19 Lbs per foot. AAVID 73110. Only .43C\W per 6" but hopefully 24" per channel will be OK with 4 pr outputs
#1917 |
Wow, they are only .43C/W? Are they made of plastic?
Seriously, where did you find them - they would be perfect for my little project...
Pillage Before You Burn. |
#1918 | |
#1919 |
Fast is fine. Get it over with. A supplier of originals would help ease the pain....
#1920 | |
http://cgi.ebay.com/ws/eBayISAPI.dll...m=330157426031 |
| Page generated in 0.12660 seconds (66.10% PHP - 33.90% MySQL) with 11 queries |
