#1411 |
Sorry, didn't notice link went to main search page. Look at http://www.fischerelektronik.de/fisc...cher/D.1.E.pdf and see what you think would be best.
Bob G. |
#1413 |
It appears that the LA 1 series has a higher dissipation capacity than the LA 2 (but also noisier), and the A-Type with the mounting fins offers the greatest device mounting flexibility. But Jacco's suggestion for the B-Type mounting looks promising also. I would prefer the LA-1-03-A (overall length 161.6mm) or the LA-1-04-A (overall length 198.1mm) for vertical mounting in 7"+ or 8"+ tall case.
Robert |
#1414 | |
Official Court Jester
hehe http://www.diyaudio.com/forums/attac...amp=1173001256
my Papa is smarter than your Nelson ! tnx to |
#1415 | |
Regards Flodstroem |
#1416 | |
I would be interested in a group buy, but I'm looking for something like a MF25-151.5 (25 cm wide), and 40 cm high. So it will be a standing design with the fins running vertically. A single heatsink per monoblock -so it may have to be a bit wider or higher. |
#1417 |
Just out of curiosity, has anyone actually finished building his boards yet? Or is it still just organising the ancillary hardware?
#1418 | |
AndrewT in post 1040 calculated .09C\W @60c per channel as the minimum acceptable for passive cooling. The MF25-151 looks like .29C\W @80c. Seems way too small. In fact the selection of a pair of heatsinks less than .18C\W each is very limited. Someone estimated a usable heatsink at 10kg. This is why I am investigating forced cooling. Bob G. |
#1419 | |
I'm not against forced cooling with a slow fan, but I really dislike the amount of dust that collects and degrades cooling. (And is generally dislikable.) Anyway, I'll set Iq according to the thermal capacity of the heatsink, and I'm planning a low Iq setting for A/V use and as an always-on mode. I can barely get my KSA 50S to go into the highest bias plateu without my ears bleeding, so the KSA100 is a bit of overkill anyway! ;-) |
#1420 |
"assuming termal resistance scales linearly"
I was informed that doubling the height of a heat sink does not double the capacity. As the air rises it heats and is not the same as two separate heat sinks side by side. Yours may indeed work; I am just repeating what I was told by a manufacturer about height. The manufacturer disappointed me with news about my height, and my girlfriend disappointed me with news about my length. Rough times I tell ya..
Troy Thinking positive doesn't make things better, it makes you a better person. |
| Page generated in 0.13498 seconds (73.39% PHP - 26.61% MySQL) with 11 queries |
