Old 12th February 2007, 01:54 PM   #1201
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
In case anyone scratches the silkscreen of his boards or damages it in any other way at a later stage :
Both board and silkscreen are usually epoxy resin based. Sometimes the silkscreen has a polyurethane base, basically the only other stuff that has a good holding grip on epoxy resin materials.
Both epoxy resin and polyurethane can be given a preferred color by adding the appropriate pigment.
Scratches and bruises can be touched up with a disposable brush.
After the curing time, the touch-up can be polished to look invisible.
Looks like Sponge Bob has killed another thread.
Old 12th February 2007, 06:28 PM   #1202
TomWaits's Avatar
Thumbs up Exceptional
It has been said already and I don't want to be redundant but the boards are fantastic! No scratches or scuffs on these ones.
I tip my hat toward you folks who put it together and the DIY forum in general as a wonderful place for all things audio.
Now if only my schedule would allow me to get back to finishing the KSA50 then I could get on to it's big brother. I guess I can start sourcing the parts.
Shawn.
Old 13th February 2007, 08:32 PM   #1203
VT67 is offline VT67  Belgium
VT67's Avatar
Still no boards overhere
Old 13th February 2007, 08:39 PM   #1204
K-amps is offline K-amps  United States
K-amps's Avatar
Originally posted by MikeBarton
.....This would give about 59v dc according to previous calculations in this thread.
Mike
FWIW... I just finished a mod to a power amp whereby the rails are about 58.5 or 59vdc.
I get 190watts per channel before clipping.... that's a very hi rail for a true KSA-100... unless u are building a KSA-150... then it will be on the money... but then jack all power sections up by 50% as well and have preceeding circuitry able to handle it too...
PS: Has anyone compared a finished KSA-50 to the KSA-100? I know Mark liked the 100.... anyone else do it?
Old 14th February 2007, 03:06 AM   #1205
Default Heatsinks
Has there been any recommendations regarding heatsinks for this project?
I have read some of the discussions, but I am not sure if there has been a consensus reached. I am most interested in passive heatsinks. Is there a spec on thermal transfer rate that I could use as a guideline when shopping for sinks? I come across some copper heatsinks may prove interesting for the project.
thanks,
Paul
Ride hard, shoot straight and tell the truth
Old 14th February 2007, 04:24 AM   #1206
Something along the lines of what was used for the KMA-160 would work well. That is what I am going to be using on my monoblocks. 4 sinks per amp. They are available through M&M Metals.....
Mark
KSA-100 WIKI
Old 14th February 2007, 09:39 AM   #1207
Default Re: Heatsinks
Hi Kamps,
what are the corresponding Vac input and output of the transformer?
0.05 to 0.08C/W.
Since the output (3pair on each driver pair) conveniently groups into 6pairs or 4triplets you can buy either 4 off 0.2 to 0.32C/W or 6 off 0.3 to 0.48C/W
regards Andrew T.
Old 14th February 2007, 10:33 AM   #1208
Default Heatsinks
Mark, Andrew:
Thanks for the clarification.
Paul
Old 14th February 2007, 11:13 AM   #1209
Default Heatsink de-rating
I forgot to mention that each manufacturer rates their sinks at a fixed temperature difference above ambient.
As the working temperature moves towards ambient (deltaT<70Cdeg) the C/W drops off. Most manufacturers quote the deltaT and how to correct Rth s-a for lower/higher values.
The Krell 100 Klone dissipation will be about 270W on +-52Vdc supply rails. Heatsink temperature~=270*(0.05 or 0.08) = 14Cdeg to 22Cdeg+ambient (30degC to 40degC). These deltaT values (14 to 22) are very much below 70Cdeg with the result that a specified 0.05C/W will run much hotter than predicted if the de-rating is ignored.
regards Andrew T.
Old 14th February 2007, 12:15 PM   #1210
K-amps's Avatar
Default Re: Re: Heatsinks
Originally posted by AndrewT
Hi Kamps, what are the corresponding Vac input and output of the transformer?
117vac prims and 42-0-42 vac secs. At 120v mains about 43.0.43vac. 1-2kva part... never did find the exact rating. Seller claimed 2kva but size is more like 1kva.... at 4 ohm clipping of 330 watts, rails sag to only about 56.5vdc. caps 40kuF per rail. Panasonics.
Page generated in 0.15827 seconds (78.93% PHP - 21.07% MySQL) with 11 queries
