can anyone help with this?
Old 20th April 2006, 06:55 PM   #1
sdnnet3 is offline sdnnet3  United States
Default can anyone help with this?
i'm trying to build an amp to power 3 horns (40w, 8ohm, realistic super power horn from radioshack i believe) but not to sure about what exactly to do. i think that 100 - 120 watts from a power amp would be enough to power them, but i'm not sure. does anyone know of a good amp design i could use to power these.
here are two designs that looked simple enough, and (at least to me) look like they could power these 3 horns without a problem.
Old 21st April 2006, 03:20 AM   #2
jaycee is offline jaycee  United Kingdom
If they are rated 40W at 8 ohms then presumably you will put them in series. If you paralleled them you would end up driving a 2 ohm load which is not an easy task.
Personally I wouldn't bother with anything more than chip amps. Using 2x LM3886's in a bridge configuration is probably best here.
Old 21st April 2006, 05:45 PM   #3
myhrrhleine is offline myhrrhleine  Belize
myhrrhleine's Avatar
Personally, I'd use 3 separate 40watt amps.
It's much easier that way.
I don't like parallel or serial speakers.
Old 21st April 2006, 05:54 PM   #4
I support Myhr's suggestion.
Three separate amps from a common low voltage supply built into one box. i.e. a 3channel power amp.
For 3*40W a set of chip amps would be simple and cheap.
If one goes faulty you still have two good ones.
regards Andrew T.
Old 23rd April 2006, 08:14 PM   #5
many thanx everyone
Old 23rd April 2006, 08:21 PM   #6
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
TDA7294 is a good alternative. It will drive 2 ohm loads as long as supply rails are below +-20V. Furthermore, it can drive 4ohm loads with +-40V rails as long as gentle cooling is provided (its safe operating area is only limited by heat as it has a N-channel MOSFET output stage).
I use to feel like the small child in The Emperor's New Clothes tale
can anyone help with this?Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
