NAD 304 Schematic - diyAudio
Old 19th April 2006, 12:22 AM   #1
Send a message via MSN to Makofoed-6sn7
Default NAD 304 Schematic
Hello,
I have a NAD 304 that is not working as it should. I'm on the right track, but need a schematic. Nad is a hell without schematic. I know this has been up many times before, but the site on net that used to have it has removed it, guess he ****'d of NAD.
So, could any one please E-mail it to me?
Makofoed at hotmail.com
Thanks,
Magnus
The line under is true
The line above is false
Old 19th April 2006, 12:39 AM   #2
A service manual has been emailed to you
Old 19th April 2006, 12:50 AM   #3
Default Thanks!
Thank you very much!
There are very few moments you will see/hear me say this, but for the moment I love you!
Best regards,
Magnus
Old 19th April 2006, 07:11 PM   #4
Limhes is offline Limhes  Orkney Islands
Coincidentally I also have a problem with the same amp, running for some years now. Once in a while it mutes one of the channels (always the same) and it comes back on after some seconds or minutes...
Could this just be some loose solder joint or is it likely that some component is on it's end? It is quite hard to isolate the problem, since the problem isn't reproducable with my skills...
Old 19th April 2006, 09:21 PM   #5
I'll guess, it's a dry solder joint. It's very easy to get acsess to the solder side of the pcb. Just to unscrew the bottom plate. Also, chek to pot's. I had some problem with them. I still have some problems with the bass controll, I need to push the knob now and then becouse it's some times set my bass to zero... I'm just to lazy to clean/replace it.
I'm not using the NAD as a power amp, just as a pre. Now it's time to put it up to working order and actually chek if I like the sound. I got the amp at work, it's was trash becouse we didn't find the fault. It was used as a PA amp in a danceplace! Talk about waste of good sound!!
Actually I found the fault, it was a burn'd resistor and a leaky transistor. BUT, when I was cheking the voltage at the OP devices I put my probe between two point I shouldent... I was ****'d and put the amp to sleep and used it as a pre(What I needed in the first place). I have killed a lot of diodes and zener, but all the power trannies are fine.
Best regards,
Magnus
Old 3rd May 2006, 07:41 AM   #6
bekim is offline bekim  Albania
Hi all,
I'd like to join to this thread in case I bought one 304 weeks ago and, seems that I need to fix it. All trannies are ok, and I still cannot get sound from it. Even preamp seems has some problems.
Can somebody please, send me schematic for this thing? I'll appreciate it.
BTW, it is worth it 50 euro!??!
bekimh@gmail.com
looking for a pre-amp schematic steamPunk Tubes / Valves 3 3rd August 2008 02:49 PM
DBX 500 schematic d3imlay Solid State 0 2nd August 2008 06:12 PM
F3 schematic kenev Pass Labs 2 24th January 2008 04:24 PM
Need Six-pac amp schematic Sarge Tubes / Valves 1 31st July 2004 09:30 PM
Copyright 1999-2017 diyAudio
