Old 6th November 2011, 02:29 PM   #151
Default re-box?
Originally Posted by audiogeekess View Post
Yes R1 = 0k and R2 = 20k.(edit)
Thanks for that A.G.... I'm considering re-boxing this ep2500 and converting it to passive cooling with larger heatsinks. Will start a separate thread tho since this was for A500.
Old 3rd February 2012, 11:10 PM   #152
I wanted to add, that for bridge mode the volume pot for channel 2 - according to the manufacturer - must be set to gain off.
In that case - if I understood it correctly - R1 = 20k, R2 = 0K was the desired setting.
If that is correct, I would recommend to replace the current mode switch with a multi way switch, that will additionally switch the resistor on channel 2. Would be most elegant.
Or disable the mode switch. Otherwise, if the modded amp will be sold, the new owner might wonder why bridge mode does not work.
Please correct me if I am wrong,
regards Tom
Old 3rd March 2012, 05:42 PM   #153
Default Rewiring from 120v to 220v
I have a Berhinger A500 which is set to 120v input (US model). Can somebody explain to me how to rewire it to be used in 220v input countries? Thanks.
Upgrading Behringer BCD2000 project, need help/advice Bonthouse Parts 4 15th July 2011 10:20 PM
Behringer A500 power amp problem, please help? emperor Solid State 34 8th December 2010 10:42 AM
Phonic Max250 or Behringer A500 for speakers 93db?? Brit01 Solid State 13 29th July 2008 07:54 PM
Which soundcard for KX Project and measuring speakers with a Behringer ECM8000? mazeroth Multi-Way 1 28th March 2006 08:22 AM
Page generated in 0.07650 seconds (72.06% PHP - 27.94% MySQL) with 11 queries
