Behringer A500 as a DIY project - Page 12 - diyAudio
Old 20th November 2009, 11:04 PM   #111
djk is offline djk
djk's Avatar
The - input of the opamp is not the summing node,
it is not inverting in the sense that you mean. Amplifier gain
is set by R10/R61 at about 32dB.
It would probably be a good idea to have a resistor for R67, if the pot goes open during rotation
the opamp would loose input bias and latch to the rail.
I would suggest about 100K for R67. C11 should have a film bypass too.
I would like to see 'some' resistance on the input to pin 6. If the pot wasn't there that would be R66.
With the pot wide open and a bad ground loop, it would likely ruin IC2B (I've had it happen).
Unless there is more circuitry than what is shown here, the 'clip' LED is more of a distortion alert.
On musical transients the LED will not be visibly bright until it has been on about 40mS or so (40mS
is about what the pesistance of vision is). Audibility of distortion may be on the order of %10 if of less
than 1mS duration, at 40mS the threshold is about 0.3%, so this circuit is more of a distortion
alert than a clip circuit (although on steady-state signals it will be accurate).
Candidates for the Darwin Award should not read this author.
Old 20th November 2009, 11:12 PM   #112
stormsonic's Avatar
@4fun
cleaned up schematic Behringer A500
I could be wrong
LINK
Look at QSC amplifier schematic
SCHEMATIC
Old 20th November 2009, 11:27 PM   #113
stormsonic's Avatar
@djk
agree
This Behringer is not good design practice
Old 21st November 2009, 09:22 AM   #114
AKN is offline AKN  Sweden
No snake oil
AKN's Avatar
Send a message via MSN to AKN
stormsonic,
The schematic you wanted to show is not visible.
Do you agree now in that the volume pot does not alter Op-amp gain?
/ Anders
Old 21st November 2009, 10:24 AM   #115
stormsonic's Avatar
Last edited by stormsonic; 21st November 2009 at 10:50 AM. Reason: shematic not visible
Old 21st November 2009, 10:57 AM   #116
No snake oil
AKN's Avatar
Ok, that simplified schematic is incomplete. You must include the second part (R10) in the feedback divider (R10-R61). This divider determines the gain; op-amp (-) to output.
Here's how nodes will move from a positive voltage change at input.
/ Anders
Old 22nd November 2009, 03:02 PM   #117
megajocke's Avatar
Originally Posted by Xoc1 View Post
On Youtube there is a video that shows increased distortion using the A500 volume control at 60-70%
YouTube - ebaystars's Channel
I thought this might be of interest to A500 users out there!
Not surprising considering the connection of C53. Note that this capacitor does not exist in the QSC schematic and thus it should not have the distortion problem:
http://www.qsc.com/support/library/s...20One/1200.pdf
The QSC uses another opamp and a different value of the capacitor in parallell with the feedback resistor however.
Old 19th December 2009, 06:22 AM   #118
Send a message via MSN to siouxiebuff
Would someone lease send me the EP2500 schematic?
Old 19th December 2009, 08:38 AM   #119
meanman1964's Avatar
Here you go with 2 others schematics
Old 18th January 2010, 09:12 PM   #120
maunoni is offline maunoni  Italy
Hello
Someone please send me the Schematic of the A500?
I have one with a channel that it has a "random" protection insertion.
Sometime after 20 seconds, or 2 hours....
please send it to maunoni@yahoo.it
Thank you very much.
best regards
Behringer A500 power amp problem, please help? emperor Solid State 37 25th August 2015 06:56 PM
Upgrading Behringer BCD2000 project, need help/advice Bonthouse Parts 4 15th July 2011 10:20 PM
Phonic Max250 or Behringer A500 for speakers 93db?? Brit01 Solid State 13 29th July 2008 07:54 PM
Which soundcard for KX Project and measuring speakers with a Behringer ECM8000? mazeroth Multi-Way 1 28th March 2006 08:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
