Old 18th April 2006, 04:40 PM   #1
Default Krell KSA 50
I am on the way to built a
JLH Class-A 40Watts amplifier
after built the JLH Class-A 10Watts first version (1969).
I saw a lot of post about the Krell KSA 50 so I am wondering if there is a different between this 2 class A implifier.
Did someone built both ?
Anybody have a felling about that ?
Thank you.
Old 19th April 2006, 07:52 AM   #2
the Krell is a push pull ClassA design.
The JLH is a single ended ClassA design with a current sink that is not quite constant (sort of tracking with signal level).
I would expect them to sound quite different.
Each has it's own adherents.
I am a bit of a JLH fan even though I have never built any of his circuits. He wrote very clearly and is relatively easy to understand.
regards Andrew T.
Old 19th April 2006, 02:31 PM   #3
Thank for your answer Andrew
I guess the best way is to build 1 of each.
I also noticed the 'killer amp' on the forum wich will be my third one.
Anybody have other informations ?
Old 19th April 2006, 02:41 PM   #4
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Class A design too???
Old 20th April 2006, 04:31 PM   #5
killer amp can be class A and AB.
Not competly sure but almost sure..
I am sure the JLH Class-A 40Watts amplifier will be good , after I don't know for the 2 others ones.
Old 20th April 2006, 04:38 PM   #6
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
il y a aussi le PLH.
Looks like Sponge Bob has killed another thread.
Page generated in 0.09649 seconds (72.70% PHP - 27.30% MySQL) with 10 queries
