old bjt amplifier kit
Old 18th April 2006, 09:01 AM   #1
Antonix is offline Antonix  Italy
Default old bjt amplifier kit
I have 4 bjt amplifier kit and i want to make some little optimization to improve sound quality and performance with 4ohm load.
Any suggestion on it ?
Old 18th April 2006, 09:02 AM   #2
The power supply are 50 0 - 50V and the power rated is 100Wrms 8ohm.
Old 18th April 2006, 04:06 PM   #3
Jan Dupont is offline Jan Dupont  Denmark
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
If you want to drive 4 Ohm speakers it would be a very good idea to add at least one extra set of output transistors
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 19th April 2006, 08:02 AM   #4
Yes but I can't mount others output transistors.
I want to make make a little optimization to make a little more stable the output and drivers stage.
What do you think about a 100nF capacitor on E - C of Q1
and a 39pF capacatitors on B - C of Q2 and Q3 ?
Old 19th April 2006, 12:54 PM   #5
djk is offline djk
djk's Avatar
"What do you think about a 100nF capacitor on E - C of Q1 "
I would do 1µF across R7, R8 instead.
I would also use a better opamp, not too fast. A NE5534 with the correct cap would sound much better.
Bypass C4, 5, 7 with 100nF.
I would rather see R10, 11 fed from the stabilized opamp supplies. The values would need to be lowered to keep the current up.
I did a commercial design of a CFP output stage with gain, driven from an opamp, about 10 years ago. It sounded quite good.
Old 19th April 2006, 01:20 PM   #6
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Why don't you check out Jan's amp? The same idea but a little bit developed.
http://www.delta-audio.com/PA-34A.htm
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 8 pcb's in interest so far.
Old 19th April 2006, 01:38 PM   #7
djk is offline djk
djk's Avatar
Not very similar, but I like the Baker clamp with the LEDs.
Old 20th April 2006, 04:38 AM   #8
ANALOG GUY is offline ANALOG GUY  Malaysia
Send a message via MSN to ANALOG GUY
Default very interested !!!
Hi, Antonix do you have sample PCB ?
I have some idea for improve this similar circuit with error phase correction topology.
Regard
analog guy
Old 21st April 2006, 11:32 AM   #9
edl is offline edl  Hungary
edl's Avatar
Here is my amp design with OPA frontend. Cheap, simple, but powerful and sounds nice.
schema: http://edl.uw.hu/sch.jpg
parts list: http://edl.uw.hu/parts.jpg
old bjt amplifier kitHide this!Advertise here!
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
Copyright ©1999-2017 diyAudio
